Any Scangauge users in here?
Well, the Dashhawk died so went out and replaced it with a Scangauge. The 'gauge has about half the capabilities as the 'hawk, but also cost about half has much.
Has anyone had any luck getting the Fuel Pressure up on the 'gauge using Xgauge? I know it's available because the 'hawk could read it, but the Scangauge website doesn't have the codes for it.
Thanks!
Thanks!
Been running the Aeroforce Interceptor scan gauges for about 3 years and love them. How many parameters can you monitor?
I used an Aeroforce on my Lightning. It was finicky and would go into hibernation for a few days and then just miraculously start working again. I liked it though, fit great in the dash.
The Scangauge has a pretty thorough trip computer that can display up to four parameters at a time such as:
Maximum Speed
Average Speed
Maximum Coolant Temperature
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Distance to Empty
Time to Empty
Fuel to Empty
Or I can display up to four 'gauges' at a time:
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Manifold Pressure (not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
And the option to program in additional gauges, such as the Ford CAN indications:
Torque into torque coverter 07E022163A 04620516063A 3008 000200010000 CTQ ft-lbs
Alt Torque into torque converter 07E122163A 04620516063A 3008 000200010000 CTQ ft-lbs
Barometric Pressure 07E0221127 046285110627 3008 000A00080000 BAR Inches of Mercury
Cylinder Head Temperature 07E0221624 046205160624 3010 000200010000 CHT Degrees F
Transmission Fluid Temperature 07E0221674 046205160674 3010 000100080000 TFT Degrees F
Alt Transmission Fluid Temperature 07E1221674 046205160674 3010 000100080000 TFT Degrees F
Converter Speed Ratio 07E02211BA 0462451106BA 3010 000100A40000 SLP Out to in ratio
Fuel Pump Pulse Width (Bank 1) 07E0221141 046205110641 3010 000200010000 FP1 Counts
Fuel Pump Pulse Width (Bank 2) 07E0221142 046205110642 3010 000200010000 FP2 Counts
EGR Duty Cycle 07E022113C 04620511063C 3010 000100010000 EGR
Fuel Pump Duty Cycle 07E0221672 046205160672 3008 006400800000 FP
Fuel Level 07E02216C1 0462451606C1 3010 000101480000 FL %
Torque Converter Line Pressure 07E02211C0 0462851106C0 3008 000500010000 LPC PSI
Transmission Output Shaft Speed 07E02211B5 0462051106B5 3010 000100040000 OSS RPM
Transmission Gear ratio 07E022163B 04624516063B 3008 00C8007F0000 GR Ratio of RPM in to out
But so far I can't find the codes for Fuel Pressure, which is one of the main things I monitor. I found the Scangauge has cylinder heat temp along with water and inlet air temp, which is what I would monitor along with fuel pressure if I could "get it up", so to speak. My old Dashhawk only displayed water, inlet, and some crazy reading called ambient air temperature that was no where near outside air temperature yet cooler than inlet air temperature and doesn't seem to have a sensor for it anywhere on the car. Weird.
Maximum Speed
Average Speed
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Distance to Empty
Time to Empty
Fuel to Empty
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
If you turn your ignition on and off too quickly before the Aeroforce gauges boot up I agree they can be a bit finicky. But give them time to boot up normally and they are not an issue. Wish you luck on your new choice!!
