any camber issues when lowering the car
Old Apr 28, 2005 | 10:30 AM
lightningstang's Avatar
Has anyone had issues when they went to get the car alligned after lowering it I have my eibachs I just don't want to be in trouble after its lowered and have to buy other crap.
Old Apr 28, 2005 | 02:16 PM
Chaotic Bliss's Avatar
I lowered mine with the Steeda Sport Springs and had no issues at all.
It seems to kinda be luck of draw as to whether you will have problems or not. Some people have, some people haven't.
Old Apr 28, 2005 | 02:45 PM
Faber's Avatar
I installed the eibach pro kit, needed camber adjustment (ford did it for me under warranty), and an adjustable panhard rod for re-centering the axle (not required, but recommended if you install wide tires and want the axle centered as opposed to sticking out from the left side of the car)
the alignment was fine, and i drove it for 7 or 800 miles before i got the camber adjusted, and the panhard rod installed.
Old Apr 28, 2005 | 04:38 PM
Mongoose's Avatar
I had no problems with the Steeda springs however the alignment adjustment is at the limit.
Old Apr 28, 2005 | 05:39 PM
bullittman's Avatar
I installed the Eibach pro kit and also put the Steeda camber plates on . It needed about 1-1/2 less camber .
Old May 30, 2005 | 02:43 PM
Redfire 05Gt's Avatar
My alignment report
Camber
Min Nominal Max Actual
-1.25 -0.75 -.25 -1.80
Caster
6.60 7.20 7.60 7.70
Toe
-.10 0.10 0.30 0.03
Old May 30, 2005 | 03:30 PM
lostsoul's Avatar
Faber.. your telling me Ford did your alignment for free when you lowered the springs? also did you have them put on the panhard bar? I put on the eibach sports kit and been driving around, but I want to get it aligned and get that panhardbar installed.. its just sitting right now.. I'm wondering how much for would do it for.. also I recall someone saying that its only takes a low cost bolts to adjust the camber... I think. hahah
Old May 30, 2005 | 05:42 PM
169stang's Avatar
Steeda sport springs here, no issues with alignment at all.
Old Sep 29, 2005 | 05:23 PM
adrenalin's Avatar
yes, some cars will experience problems. Read this lengthy thread for more information
http://forums.bradbarnett.net/index.php?showtopic=18713
rcarrilloGTP
Sep 3, 2015 09:27 AM
SMBJoshy
Aug 24, 2015 10:55 AM
RocStar69
Aug 21, 2015 07:33 AM
Big-D
Jul 27, 2015 11:24 AM
killaz05
Jul 24, 2015 08:49 AM
