Annoying Buzzing Sound In Roush Short Throw Shifter
Old Jan 9, 2007 | 05:34 PM
Jon_Purdy's Avatar
I've had it with this thing. Early on, I loved it. A bit stiff but I could get used to that. But the buzzing sound it has developed has made me want to switch. The only way I can get it to stop buzzing is gently push down on the **** as I approach the rpm range (2000 to 2500) where it occurs. A Pro 5.0 looks like the one to get, anyone out there no of any deals?
Cheers,
Jon
Old Jan 9, 2007 | 05:40 PM
FLAstangx3's Avatar
Get under her, and check your bushing's. Or loosen the rear mount bolts, 10mm, (You'll need a deep socked) and put some padding in under the hole the shifter comes up thru. I found with my Hurst that the rear bushing was a tad narrower than the stock on, thus when I snugged it up, the shifter rubbed on the bottom of the console opening. a little extra gasket arround it, then snugged it up again, and so far, no noise.
Old Jan 9, 2007 | 07:27 PM
Jon_Purdy's Avatar
Thanks. I'll have a look tomorrow. I was thinking that it was a bad bushing. One question though, if it is a bad bushing and since the one that is directly under the shifter is a stock item, how do I go about replacing it? Is there a part number for it? I know, it's a silly question but I have to ask.
Jon
SMBJoshy
Aug 24, 2015 10:55 AM
Mackitude
Aug 13, 2015 01:05 PM
lakersfreak
Aug 12, 2015 01:52 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
ClayP
Aug 3, 2015 09:00 PM
