amsoil or ford racing friction modifier?
Old Nov 7, 2007 | 09:10 AM
YaoNYC's Avatar
hi all,
which should i use?
any dangers using amsoil?
thanks!
https://www.amsoil.com/StoreFront/Se...D=43&zo=501359
http://www.fordracingparts.com/parts...=Differentials
Old Nov 7, 2007 | 09:28 AM
RKNMACH's Avatar
I running Amsoil in the engine and RP in the transmission and rear end.
Old Nov 10, 2007 | 07:20 PM
Mineral Grey Ragtop's Avatar
First of all, the price of the two Ford Racing friction modifiers must have a typo: $3.75 for one of them and $42.00 for the other. Which is it?
Old Nov 10, 2007 | 09:39 PM
06GT4RAD's Avatar
Redline 75w140 it has the friction modifier in it already.
Richard
Old Nov 11, 2007 | 02:47 AM
ShowGT's Avatar
Very good point Richard.
Old Nov 11, 2007 | 06:37 PM
SoundGuyDave's Avatar
Richard
When I had my rear re-done, the installer used Royal Purple, and I wound up with clutch-pack moaning... R&R the fluid with Motorcraft, with Motorcraft friction modifier, and no more noise... Just my experience...
Old Nov 11, 2007 | 06:46 PM
06GT4RAD's Avatar
OK so why are you quoting me I did not suggest he use RP.
The Motorcraft 75w140 is almost double the cost of Redline Oil and the Redline is far superior. I have been using Redline for well over 20 years and it has always cured clutch pack chatter.
Richard
Old Nov 12, 2007 | 06:48 AM
YaoNYC's Avatar
thanks soundguy..
motorcraft XL friction modifier it is!
Old Nov 12, 2007 | 07:25 AM
travelers's Avatar
do them both if you hear noise
Old Nov 12, 2007 | 02:37 PM
Richard
My apologies... My post SHOULD have read: "...Royal Purple, which also has friction modifier in it, and I wound up with clutch-pack moaning..." My intent was to present info that a competing product to the Redline, which is supposedly a functional equivalent, did create issues...
Old Nov 12, 2007 | 04:59 PM
06GT4RAD's Avatar
No problem. I myself do not like RP and would never use it in anything i own. But I do not like saying that as it tends to cause a ruckus. I have seen a few independent test over the years and RP does not hold up well in any of them.
Like I said though i have been running Redline Oils for a long time and it has always cured any clutch pack chatter i have and in fact we use it at the shop i work for. It is the only thing we will use to get rid of the chatter if someone complains about it.
Richard
Old Nov 12, 2007 | 06:09 PM
SoFlaBoss's Avatar
I have a Detroit/Eaton Truetrac differential, so no synthetic gear lube or friction modifier for me! I'm using Shell Spirax HD 85w140. It's only $5 a quart vs. $22 a quart for the Motorcraft 75w140 synthetic gear lube.
Ecostang
Nov 3, 2022 08:50 PM
Blown CS
Aug 7, 2015 10:22 AM
MADSCOTSMAN
Jul 22, 2015 04:57 PM
