Aluminum Driveshaft Failure at 70 mph...
Old May 24, 2007 | 01:59 PM
  #141
Robbieg's Avatar
Originally Posted by SoCal94
If the driveshaft was scaping on anything, there will be obvious scratches that go in circles right around it. The problem is, when that happens, the shaft is a lot weaker at that point. Generally if that happens you should be planning to replace it.
I've been running the Ford aluminum driveshaft on our '94 since '99 or so, with no problems. So, it was the install or the construction of the shaft that was the problem - not the fact that it was aluminum.
Good luck!
SoCal94
I think you are right, it was definitely not because it was aluminum because it wasn't aluminum.
Old Jun 12, 2007 | 06:15 PM
  #142
2bone123's Avatar
Originally Posted by My05
Thanks for the recommendations. I contacted one lawyer late last night by email and I'm waiting to hear back from them. I also contacted the pre-paid legal service and asked them if I should have a lawyer looking at my situation at this point, they responded and said "you already have 3 overseeing it".
What they told me was that so far what I have been doing has been the correct path and that it will only help once B.A.R. finishes their report and we get confirmation that the shop owner will not pay. I was also told by them that once B.A.R. presents their findings to the shop owner they typically have 30 days to pay, (that they have to be given time to pay) and after that we begin the civil suit.
I'm going to confirm this process when I hear back fro mthe outside attorney and begin to get a feel for their suggestions as well. I've been following the advice from them so far because my main concern is protecting myself as well, but I will double check this with an outside attorney.
Thank you again for helping me make sure I'm covering myself the best way possible.
Also, from my theoretical questions to my insurance, "if" an aftermarket part was the cause of the damage it would not be covered. As it is, I don't want to file claim against my insurance if it's the fault of someone else, and I certainly don't want any suspicions of insurance fraud on my part.
Thanks everyone.
Hey MY05, It's been awhile since posting, anything happening?
Old Jun 12, 2007 | 09:29 PM
  #143
JonCo's Avatar
I've seen this thread listed in the forums since it started. And I never botherd reading the contents or anything. All I have to say is...
MY05, any new news?
Old Jun 13, 2007 | 09:19 PM
  #144
My05's Avatar
Yeah, all has been quiet but we're moving forward towards a lawsuit. Everything moves slowly as docs are gathered, stuff is mailed out, etc. Once some dates are established I'll post em!
Old Jun 13, 2007 | 10:36 PM
  #145
future9er24's Avatar
Oh man!!! First and foremost I am glad you and your daughter are unharmed. This is one terrible incident, and I'll be rootin for you. Hope this all gets covered by those who have fouled up
And I'm definately with you in wishin people would own up to their mistakes
Old Jun 13, 2007 | 11:48 PM
  #146
DynamicmustangGT's Avatar
Hope you get a new pony soon. I want to see some justice out of this whole thing.
Old Jun 14, 2007 | 01:12 AM
  #147
rmays06's Avatar
WOW man this is absolutly scary. I just got an Alum D/S installed no problems, vibrations or noises, but scary non the less.
I hope the best for you man and I hope you get what you have coming rightfully to you. I would IMO have a lawyer thou.
Keep us informed.
Old Jun 14, 2007 | 03:44 PM
  #148
Francis's Avatar
Hey My05 - any news? We're pulling for ya I wonder if it's possible to sue this guy for wreckless endangerment or something for putting you and your daughter at risk. Maybe you can do that to force the guy into a settlement.
General question about driveshafts though: Why don't we see more carbon fibre driveshafts being used? Seems a lot of the import guys are using them now.
It seems ideal (other than the price).
1) We want to reduce rotational mass - this is why we prefer lighter driveshafts.
2) We want a stronger driveshaft - So we avoid driveshaft destruction after putting all those power enhancing mods up front.
So it seems like carbon fiber is a better choice here, because it's stronger than aluminum, for its mass.
But the reason I bring it up here is that I've been told it's a lot safer too. A carbon fiber driveshaft, under failure, will splinter into a million pieces instead of smacking around into your passenger compartment.
Thoughts?
Old Jun 14, 2007 | 03:48 PM
  #149
kevinb120's Avatar
Keep us informed.
You did notice that it was not an aluminum driveshaft?
AND POST SOMETHING QUICK YOU ARE ON 666
Old Jun 14, 2007 | 05:39 PM
  #150
spyder7724's Avatar
Thoughts?
the drawback to carbon fiber is when it breaks and splinters the shards are like little razor blades with lots of inertia. the fuel tank surrounds the driveshaft so it could get messy and if your running slicks or drag radials the might be history. this is a problem formula one has with the carbon bodywork on their cars. just get a good aluminum driveshaft (preferably a spydershaft) and use both front and rear saftey loops.
what happened to my05 is a dishonest shop didn't install what they promised then didn't back up what they installed so don't be nervous unless you had the same place install one for you.
Old Jun 14, 2007 | 05:52 PM
  #151
rmays06's Avatar
Kevin thanks man I took car of the 666 post....lol
To answer the carbon fiber question a little to. Right now there is a shortage in the country not a dangerous shortage but enought of one to drive up cost and if the fiber gets 1 knick it takes the a bit of strength out of the shaft add those up and you have a splinter factory at 3000 RPM's
just my thoughts.
Old Jun 14, 2007 | 11:04 PM
  #152
kevinb120's Avatar
They have tons of 350z's with the CF factory driveshaft
Although it weighs exactly the same as the AL one for more loot so its kinda silly.
Old Jun 14, 2007 | 11:16 PM
  #153
What a waste to go CF anyway the hoods are like 2lbs lighterwhen painted not worth the difference in price
Old Jun 14, 2007 | 11:18 PM
  #154
LAK3RS's Avatar
SPYDERSHAFT all the way!!!!!!!!
Old Jul 9, 2007 | 05:07 PM
  #155
VegasGold's Avatar
Bump...Any update? It has been some time now...Have a new Mustang?
Old Jul 9, 2007 | 05:32 PM
  #156
My05's Avatar
Thanks for checking, things should get interesting shortly, I'm getting ready to file the lawsuit and doing all of the due diligence upfront... But you can bet I"ll be updating things as they unfold.....
Old Jul 9, 2007 | 05:41 PM
  #157
VegasGold's Avatar
Thank you for the update. I can not believe it has been this long and you are still with out a new Mustang...Good luck...Add stress to it etc, etc, to your claim. I would add everything I could think of for this taking so long...
Keep us updated...Best of luck...
Old Aug 14, 2007 | 01:30 AM
  #158
rmays06's Avatar
Anything new with this?
Old Aug 14, 2007 | 06:24 AM
  #159
htwag's Avatar
Good luck. Get a lawyer.
Old Aug 14, 2007 | 10:56 AM
  #160
paradigm1220's Avatar
I've been thourgh the legal system a few times and I know what you're going through. On top of the inconvenience and frustrations of dealing with this terrible wrongdoing, whether the blame lay with the installer or manufacturer, the legal system makes for very bad headaches. Just be patient. Like I'd rather find Waldo in a crowd of the entire world than deal with the courts.
