Alignment Specs
Old Aug 29, 2005 | 09:05 AM
covertaxn's Avatar
Does anyone know the alignment specs for the 05 GT? I had mine lowered by the dealer with Eibach Prolines during the front end TSB. Afterwards, he said all parameters were within soec. But the right front was carrying a noticibally different camber. Took it to an alignment shop, and they had to install one of the camber bolts recommended by Affixer. Looks great now, however i noticed that the spec sheet i got was for the 2004. Here is the specs:
Left
camber actual: -.06 before:-.06 range: -1.3 - .03
caster 7.4 7.4 2.5 - 4.0
Toe .04 .08 0.0 - .25
Right
camber -0.6 -1.3
caster 7.8 7.8
toe .04 .07
cross camber 0.0 .7 -.8 - .8
cross caster -.5 -.4 -.8 - .8
total toe .08 .16 0.0 - .50
Thanks for the help.
Keith
Old Aug 29, 2005 | 09:30 AM
FordRacing's Avatar
You can find the specs here; about 2/3 of the way down on the first page.
http://forums.bradbarnett.net/index.php?sh...713&hl=aligment
Old Aug 29, 2005 | 10:26 PM
covertaxn's Avatar
Thank you Sir!
Old Aug 30, 2005 | 12:26 AM
mikeelia's Avatar
Here's what mine is set to:
______________frt lft________rgt frt________spec range [Ford]
camber________-0.1________0.1____________-1.3 to -0.3
caster__________7.5________7.4_____________6.6 to 7.6
toe____________0.07_______-0.04___________-0.05 to 0.16
SAI____________16.1________15.5
included angle__15.9________15.6
The camber is set intentionally out of spec to improve tire wear and look and I have the Steeda Comp Springss and [non-Steeda] camber adjusters.
Hope that helps. [sorry about the formatting effort].
Mike Elia
SoCal
OneCoolGT
Dec 10, 2015 07:55 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
Allen Hanback
Sep 14, 2015 04:37 PM
robjh22
Sep 8, 2015 12:31 PM
