Airbag wiring harness question...
Well I traded interiors with SUBZERO. I believe his interior is off of an 07 GT like mine. Here's the problem...
Under each seat is two harnesses. One for the side airbags, and one the motor on the driver side (not sure why there is two harnesses on the pass. side when there isn't power). The driver side harnesses mate up perfectly with no problems. However when I went to plug in the two harnesses on the passanger side, only the yellow harness mated up. His harness coming out of his seat didn't match up with the grey and black harness coming out from under my carpet. They won't fit at all, mine is a square shaped harness and his is rectangular with a lot more prongs. I'm not sure what to do? It's obviously the airbag harness because my airbag light is on.
Any input is appreciated!
--Brandon
--Brandon
