Airaid cai
Old 5/16/11 | 05:41 PM
Cdlax93's Avatar
Airaid cai
Has anyone heard any good things about this brand? I've heard good things about jlt bbk c&l and steeda but from my understanding they all require a tune which I don't have money for ATM. But airaid doesn't require a tune but I haven't heard anything about them.
Old 5/16/11 | 10:16 PM
Enfynet's Avatar
90% of your CAI gain will be the tune. Until then I'd suggest a K&N drop in filter.
Old 5/17/11 | 01:26 AM
Everett's Avatar
On anything older than a 3v save your money and buy a parts that helps power. Cai doesn't do ****
Old 5/17/11 | 05:37 AM
topbliss's Avatar
They are nice cai's that can be run without a tune.. Its a nice alternative to install and run without a tune and save your $ for a tune later.. You can then remove the maf restrictor and slap a tune on it and it will flow as well any any other cai// My father in law has one in his 08 Gt and its a nice one..
Old 5/17/11 | 07:38 AM
Gtpony325's Avatar
I have and airaid cai on my 07 gt. Works great but i would definately recomend getting a tune with it. When i put mine on i threw a lean code. After the tune it was perfect. Definately wakes the car up a little bit.
Old 5/20/11 | 05:09 AM
topbliss's Avatar
did you have the maf restrictor installed? If so the cai will not throw a lean code..
Old 5/21/11 | 06:34 AM
crescent_wrench's Avatar
From what i've heard, they make a quality product with OEM like fit and finish.
Old 5/23/11 | 04:31 PM
catman's Avatar
I've had the Airaid CAI on my 06 GT for about four years. I ran it without a tune with no problems for about half that time, and then with Brenspeed tunes for the past couple of years. Definitely pair the CAI with a tune, even though the Airaid, like the K &N, are ostensibly able to run without a tune. There is a thread or two somewhere where either the folks at Brenspeed or one of the other popular shops dynoed a GT with the restrictor tube in and out and, if memory serves, there wasn't much difference in performance between the two (although removing the restrictor tube definitely requires a tune).
There are other very good CAIs out there, but I have been very happy with the Airaid/Roush unit.
Old 5/29/11 | 04:22 PM
randy_tho's Avatar
I also ran the airaid for several months and then picked up a brenspeed tune. Just be sure that you don't end up spending more money than buying them together. It makes a slight difference in feel and the intake noise sounds good along with a ~1-2 MPG increase. With a tune though the car completely wakes up. I run with the restrictor in as brenspeed recommended it unless paired with cams or fi.
14_GT/CS
2011 - 2014 GT/CS
12
3/24/16 12:20 PM
MustangConvert11
9/30/15 08:01 PM
exgto
2012-2013 BOSS 302
9/28/15 07:39 PM
samjluck
9/17/15 10:24 PM
TripleBlack14
9/17/15 07:48 AM
Quick Reply: Airaid cai
