Aftermarket Gauges 12switched power source?
Old Dec 14, 2006 | 02:06 PM
06GTwJUICE's Avatar
Just curious for those who have aftermarket gauges, where you tapped into the 12v switched power?
I will be running wires this weekend when it's raining and was curious if anyone had anything close to the apillar to tap into?
thanks jake
Old Dec 14, 2006 | 03:12 PM
sook's Avatar
I had to run a long wire along the firewall from the driver's side A-Pillar to the interior fuse box on the passenger side. From there I soldered in an "add-a-circuit" from autozone. Slots 5 and 13 are unused and give you switched power. I'm sure you can power the gauges by tapping a wire from under the instrument panel or from the stereo.
Old Dec 14, 2006 | 05:37 PM
06GTwJUICE's Avatar
I'll try the add-a-circuit route.
my last car had about 6 gauges tapped under the dash and it looked like crap and was always to me a fire hazzard.. hahahaha
Old Dec 14, 2006 | 05:41 PM
06GTwJUICE's Avatar
thanks sook
Old Dec 14, 2006 | 08:25 PM
redbullet's Avatar
thanks jake
I used the RED wire leading to the Brake Position Switch. This switch is ABOVE the Stop Lamp Switch on the brake pedal bracket. I cheated and used a Scotch Lock.
This wire is hot in crank/run as required for the newer Autometer gauges.
Old Dec 14, 2006 | 10:06 PM
06GTwJUICE's Avatar
thanks redbullet....
Old Dec 22, 2006 | 10:19 PM
flamin ponyexpress's Avatar
redbullet, do you have a picture of the location on the red wire?
Old Dec 23, 2006 | 06:38 AM
redbullet's Avatar
No, but I sent you a PM.....
Old Dec 23, 2006 | 08:44 AM
got it ,Thanks! the additional info is all I needed.
Old Dec 23, 2006 | 11:48 AM
06GTwJUICE's Avatar
can you guys hit me with that info as well...
i see what i think is it..
red wire and purple wire with red stripe... attached to the brake position switch... it's only two wire... or am i looking for anohter wire bundle?
As for lighting... i think i have that covered in another post.
thanks
jake
Old Dec 23, 2006 | 02:10 PM
thanks
jake
Jake the switch that you want to use is light blue and the wires are solid red and light blue/red tracer. use the solid red wire only.
As far as lights on the gages I used the light switch on the car. that way when I turn on my light switch the gage light comes on.sorry I can't remember which wire it is on the light switch. I'll look at my pictures to see if I took one of the light switch wire and let you know.
Hope this helps! thanks to redbullet for his additional info. I can't take all the credit. He was alot of help in finding the solid red wire for the run/crank mood.
Old Dec 23, 2006 | 02:31 PM
06GTwJUICE's Avatar
worked like a charm..
thanks guys.
you were both lots of help.
everything works too....
hahahahha
Old Dec 23, 2006 | 03:05 PM
SONICBOOST's Avatar
Sorry for the hijack but I have a question. I am getting a supercharger and i'm going to order the mrt guage pod and I was wondering what three guages do I need, thank's
-Adam
Old Dec 23, 2006 | 06:00 PM
thanks guys.
hahahahha
I see you installed the Nexus series gages, I was going to ,but I got a full sponsorship on the Cobalt series, if I went with the Nexus series was only going to be partial sponsorship, so I oped to go with the Cobalt series. My DPSS ahift light is the stage 2 like yours. Auto Meter has treated me very well. a very good sponsor to be with.
Old Dec 23, 2006 | 06:06 PM
thanks guys.
hahahahha
Sorry for misunderstanding ,you have nitrous gage, I mis read it as the Nexus series gages. my bad.
Old Dec 23, 2006 | 06:31 PM
06GTwJUICE's Avatar
so have you hooked that dpss up yet?
i'm going to work on the tach adapter and dpss install tomorrow
and then tuesday call nitrous express on the tps learning switch if the forum post dont get replies.
thanks again...
jake
Old Dec 24, 2006 | 10:54 AM
thanks again...
jake
Jake, Did the pictures I sent you Help? let me know if you need any additional info?
Merry Christmas !
Old Dec 24, 2006 | 12:04 PM
06GTwJUICE's Avatar
Brother.... the pictures you sent me are going to be VERY usefull here in about 30 minutes.
I ran out to get a multimeter(tps voltage test) and a couple switches(bottle heater) and heat shrink (the tach install).
I'm going to cook some breakfast and then git er done.
merry xmas to you to...
and many thanks for the pictures.
CiniZter
25
Apr 28, 2016 05:41 PM
