Aeroforcetech Gauges came today. WHAT a product
Old Sep 26, 2007 | 05:52 PM
94tbird's Avatar
I think i like these better than my nexus gauges!!!!
Currently i have them set up to monitor ambient air temp and intake temp on the primary and on the secondary Oil temp, Coolant temp and RPM. These will also monitor injector duty cycle, fuel pump duty cycle and many others. ill include a partial list because i got tired of writing them down haha.
EDIT. we dont have a stock oil temp sender so im not sure what its reading there. im going to install one for sure and hook it up to the analog in on the gauge.
It also allows you to select multiple PID's and it will either auto scroll through them or stay on 2 of them until you tell it to scroll.
also has a reverse 90 degree connector for the OBD2 port. it doesnt get in the way of shifting either
Intake Air Temp
Ambient Temp
Coolant Temp
Trans Temp - Automatics
RPM
Maf Sensor LBS/Minute
MAF Counts
Injector Pulse Width
Injector Duty Cycle
Manifold PSI
Throttle Position(this was pretty cool to see)
Throttle Volts
MPH
Knock Retard
Ignition Advance
Short Term Fuel bank 1 and bank 2
Long term fuel trim Bank 1 and 2
Oxygen sensor bank 1 and 2
Battery Voltage
Engine Load
Fuel pressure at the rail
Fuel Pump Duty Cycle
Cylinder head Temp
Oil Temp
MPG
Calculated Net HP
Calculated engine torque (auto trans)
Trans slip (auto)
It can also record 0-60 times 1/8 mile times and 1/4 mile times
has a built in shift light too and 2 analog inputs for external sensors that ford doesn't include stock
I will be mounting these in the SOS dual a pillar pod once the 3 pod dash pod comes out. Ill move all my nexus and AEM gauges there and in the center vent pod when its out. These gauges are awesome!
here are some pics. sorry for the quaility. my camera wont let me turn off the flash so i put blue tape or my finger over it lol
Old Sep 26, 2007 | 06:11 PM
tom281's Avatar
Nice socks LOL.... got a link to the guages, they seem awesome!
Old Sep 26, 2007 | 06:14 PM
94tbird's Avatar
group buy gonig on here apparently
http://www.modularfords.com/forums/f...tml#post974112
Old Sep 26, 2007 | 06:16 PM
ShowGT's Avatar
Nice setup.
Old Sep 26, 2007 | 06:50 PM
tom281's Avatar
Thanks Ron, I pm'ed the dude and may buy a pair.
Old Sep 26, 2007 | 06:51 PM
94tbird's Avatar
no problem
Old Sep 27, 2007 | 06:04 AM
dly's Avatar
dly
What else would this gauge need to run as a wideband A/F??
Old Sep 27, 2007 | 07:05 AM
tom281's Avatar
Darrell, I've asked the vendor on Modfords about that.... I 'll let you know what I find out.
Old Sep 27, 2007 | 07:11 AM
dly's Avatar
dly
Cool let me know and also how to order one of these bad boys.
Old Sep 27, 2007 | 08:50 AM
94tbird's Avatar
to do AFR i beleive you will need a calibrated Wideband oxygen sensor similar to the ones used by AEM and Autometer. They can be had for about 50-70 bucks if you do your research. I would cut off their proprietary connector, and splice the power, ground, and signal wires to the included Analog wires supplied with the aeroforce kit. since the Sensors are a 0-5v signal and the analog for the aeroforce gauges are also 0-5v there shouldnt be any problems.
Old Sep 27, 2007 | 10:00 AM
tom281's Avatar
You can check out the link Ron provided above (to modfords) to order one or two gauges at a special price until the end of the month.
Old Sep 27, 2007 | 11:17 AM
TheRealOne's Avatar
Is there a way to conceal the cable?
Old Sep 27, 2007 | 11:55 AM
TRMN8TR's Avatar
i've got mine coming tomorrow. i will route the cable up the a pillar and into the sos pods. i'll post pics, can't wait to get it, it's an awesome tool! Thanks Todd and AeroForce
Old Sep 27, 2007 | 03:10 PM
Falchion's Avatar
Thanks for the info! Looking forward to some pics!
Old Sep 27, 2007 | 03:19 PM
Do they still have the blue color available. Im not a big fan of Ford's green guages and buttons and junk. I dont suppose that there's anyway to change those - like I assume the door lock switches and everything is greeen.
Old Sep 27, 2007 | 03:36 PM
Falchion's Avatar
Looks like you can get it in blue. This is from the second post on the group buy link above.
I should add that you can get these with green, blue, red, or white backlighting. Faces can be silver, white, or black. Bezels can be black, silver, or chrome. You'll need to state these preferences in your order.
Old Sep 27, 2007 | 03:37 PM
tom281's Avatar
I just sent them an email thru their "sales" address on their website, I want to get in on this deal before the weekend.
Old Sep 27, 2007 | 04:39 PM
msully's Avatar
Can you get boost pressure with these?
Old Sep 27, 2007 | 06:41 PM
n8rfastback's Avatar
oh yea you can!!!
Old Sep 28, 2007 | 11:36 AM
Falchion's Avatar
I wasn't able to get ahold of Todd via E-mail, or PM on ModularFords. Is there a better way to get ahold of him?
