ABS Brakes and after-market Rear Diffs
Old Jan 19, 2006 | 04:05 PM
esorense's Avatar
Thumbs up
I've heard the stock rear diffs on the S197 Mustangs equipped with anti-lock brakes have a toothed rim around the circumference of the 'spindle' portion of the rear differential. I have not taken apart my rear axle (YET! ) so I cannot confirm this. The purpose for the toothed rim is to allow the ABS to work. I'm seeking to upgrade my rear axle to a Detroit TrueTrac unit. However, every Detroit TrueTrac I have seen the 'Spindle' on the axle has a smooth circumference, not toothed.
  1. Does anyone know if the spindle on the 05+ S197 Mustangs equipped with ABSis toothed or smooth as shipped from the factory.
  2. Has anyone who has swapped out the rear end for Auburn/Ford Racing/Detroit rear axle with a Smooth/untoothed spindle noticed that their ABS no longer works?
Thanks for the replies.
Old Jan 19, 2006 | 06:42 PM
esorense's Avatar
Originally posted by Blazing Saddles@January 19, 2006, 8:44 PM
The ABS exciter rings are pressed onto the axles. You can change the differential carrier without affecting the ABS brakes. I put an Eaton posi in mine.
Thank you!
joemad59
Dec 30, 2015 06:13 PM
Fords4Ever
Oct 30, 2015 09:07 PM
Sep 16, 2015 06:44 PM
1001yos
Sep 8, 2015 10:05 PM
Sep 8, 2015 10:45 AM
