$900 bucks in mods to run 12s
Old Apr 18, 2005 | 10:49 PM
max2000jp's Avatar
I have already installed a C&L intake and Predator for a cost of 700 dollars(I could have done better, but I wanted it quickly). I plan on buying a Mak off-road x-pipe soon at a cost of $199 plus shipping. I think that will put me at or above 300 rwhp from what I have seen. I figure that should be good for high 12's on street tires, assuming I can cut off a good 60' time. Think this is a reasonable goal? I think 900 dollars to run high 12s on street tires is a great bang for the buck. If I can't do it on street tires, my friend has some MT ET streets that I can borrow
Old Apr 18, 2005 | 11:04 PM
dhof303's Avatar
Stock 05 Mustang GT with manual trans and good driver/ET streets = High 12s.
You should be able to do it without the slicks but it will take a lot of runs to get the launch right without wheel hop.
Old Apr 19, 2005 | 09:11 AM
gotan05's Avatar
[quote=dhof303,April 19, 2005, 9:07 AM]
If you could accomplish that, you would be the man. I forgot which mag it was, but it took them like $2400 to do it. You would definitely prove them wrong. And shut up a lot of LS1 guys
Old Apr 19, 2005 | 09:20 AM
max2000jp's Avatar
I am going to the track this Friday, without the x-pipe for some baselines. When it gets cooler out, I am sure we will see a lot of 12 second times with minimal mods. This engine responds real well to simple cost effective mods.
Old Apr 19, 2005 | 09:35 AM
idobson's Avatar
Just squirt some nitrous in there and I'm sure you could do it for less than that
Old Apr 19, 2005 | 12:12 PM
SurfnSoCal's Avatar
MM&FF did a "6 pack" with $2,400 in mods.
From memory-
Mickey Thompson's
SCT Tune
removed HC trap
axle back exhaust
gears
UD pullies
That got them in to the high 12's. If you have $900 to spend AFTER youi already got the intake and tuner....you should be able to do it. Do gears and the Pullies first. See what you run on the stock tires.
Also, I would suggest a pair of LCA's to help your launches.
good luck.
Old Apr 19, 2005 | 01:28 PM
sranger's Avatar
Probably not, but....
I would make the attempt with $900.00 I would try:
1) Under Drive pullys instead of the cold air intake. Removing the carbon trap is nearly as effective.
2) Preditor tune.
3) Removing the back seat and installing carpet ( minimal cost )
4) 4:11 gears in the rear end.
This shoud give the biggest boost for around $900.00
I do not think the exhaust system will do much since the stock system h pipe and 2.5" duals is very efficient. I think changing the sound is about all they will really do...
That would be my attempt for $900.00
Old Apr 19, 2005 | 11:58 PM
stkdidy's Avatar
take out hc trap: free
take out spare: free
take out rear seat: free (but no need...it only weighs 5lb)
take out pass seat: free
deflate tires to 25psi: free
jlt cai: 180
predator: 400
4.10 gears: 450 installed
lil over 1k$, but id say u could manage high 12s if u get 60' down to ~2sec
then pulleys: 200
charge-motion plates: ?
long tubes: 500~ probly 1000 for them and new exhaust
mt streets: 400~?
2k$ and ur down to 12.5 easy
Old Apr 24, 2005 | 05:12 AM
Stang281's Avatar
From memory-
Mickey Thompson's
SCT Tune
removed HC trap
axle back exhaust
gears
UD pullies
good luck.
Actually, it was mid 12's, one full second faster for $2400. Their times were ~12.4/5's
And what's up Jason? I had never seen you post on here before.
Old Apr 24, 2005 | 05:15 AM
Stang281's Avatar
jlt cai: 180
predator: 400
then pulleys: 200
mt streets: 400~?
The rear seats are ~40+lbs...
Sep 8, 2015 10:45 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
earl610
Sep 6, 2015 05:48 PM
Cdvision
Sep 5, 2015 05:22 PM
