5sp Automatic help
Old Jul 28, 2005 | 09:35 PM
Bluejoker's Avatar
I bought my car last december. Whenever i stop the car, put it into park, and let off the brake the car rocks back and then the shifter clicks into park... its quite annoying, anyone know a fix?
its a automatic and has always done this...
Old Jul 28, 2005 | 09:40 PM
GtStallion51's Avatar
Mine does that too; not all the time though. It doesn't bother me too much because my 02 did the same thing. It would be cool if there was a fix though.
Old Jul 29, 2005 | 06:21 AM
SC67Stang's Avatar
Mine also does this, but so does my F-150.
Make sure you don't park too close front or back to anything depending on the slope.
Steve
Old Jul 29, 2005 | 06:36 AM
364's Avatar
364
Mine does this too. I thought it was a glitch in my tranny. I was going to take it into the dealer next week, but I guess it's just something we have to live with. Thanks for saving me a trip to the dealer.
Old Jul 29, 2005 | 08:44 AM
SixtySix's Avatar
Stop the car, put it into Park, DON'T let off the brake, engage the e-brake, Now let off the brake and shut off the car.
Problem solved.
Old Jul 29, 2005 | 09:38 AM
sodaman's Avatar
same problem here. I just make sure to apply e brake after setting. I took it too dealer, they said that is normal. I figured it was just a linkage adjustment. But maybe there linkage isnt adjustable. good luck
Old Jul 29, 2005 | 09:43 AM
E-Rock's Avatar
Problem solved.
I've always done it that way. Maybe that's why I never noticed the roll back.
Old Jul 29, 2005 | 10:18 AM
Bluejoker's Avatar
Thanks for the replies, made an appointment with dealership to have it looked at (along with a fix for the gas tank, and CD player) this wed. I'll report back then.
Thanks again.
Old Jul 29, 2005 | 10:32 AM
tmcolegr's Avatar
Good luck on the CD player! I'm on my 3rd skipper 1000.
Old Jul 29, 2005 | 10:40 AM
SixtySix's Avatar
Wow, I got lucky. I'm still on my original and everything is hunky dory!
Old Jul 29, 2005 | 11:22 AM
friedmaster's Avatar
every automatic car i have driven does that when on a slope. I think it may just be something to do with the way auto transmissions are designed. What it also does is if somebody hits you while your parked, it will allow your car to roll a bit. Because of this, this may be the way auto trannys are designed so that you dont break something if someone bumps you while parallel parking.
Old Jul 29, 2005 | 12:51 PM
fastball25's Avatar
Problem solved.
It actually works better if you apply the e-brake before putting the vehicle in Park. Every vehicle I have ever driven still rolled slightly if I put the e-brake on after putting it into park.
Old Jul 29, 2005 | 05:12 PM
GhostGT's Avatar
Comon guys you all should know better than that . Stopping and pulling into PARK leaves a few inches of rollaway for the car, especially if you are on a slight slope. Pull into park, KEEP YOUR FOOT ON THE BRAKES, and pull the ebrake. Its as simple as that. The ebrake will hold the car in place.
Old Aug 4, 2005 | 09:38 PM
Bluejoker's Avatar
update:
dealer says 'normal'. So I suppose I'll live with it, the E brake solution works quite well. The dealership is going to replace the gas tank & CD player
Old Aug 4, 2005 | 09:47 PM
cambostang's Avatar
mine does the same thing but my other cars with auto tranny didn't do this. you put it in park and it stays there and no click after it's in park just right when you hit park. it's very annoying to me. i never put the e-brake on unless i'm on a slope which is far and few between here in florida. it doens't do it if I slam the shifter up hard and it clicks right in to park and it doens't rock back. try doing that guys and see if it helps.. it doens't seem like it's lined up right.
jim010
Jun 24, 2024 04:23 PM
yabutt
Oct 23, 2015 01:05 PM
mabupa
Sep 23, 2015 12:17 PM
BackroadGT
V6 Performance Mods
Sep 22, 2015 07:13 PM
Fernando.4ohh
Sep 10, 2015 03:35 PM
