4:10 Gears Installed Today - Part ll
Old 1/25/06, 06:40 PM
GRAYPNY's Avatar
I just got my car back from the shop and they are PERFECT! I took the install sheet that Dustin emailed to me and they called the Ford service hotline and got it right. The orginial quote was for 4 hours at $75 per hour so $300. The shop spent approximate 8 hours on the car and the price was still the same. I gave the owner (small shop) a $100 tip.
BTW Robert (the Owner) said bring it back in 500 miles and he would change out the gear oil and not charge me for the labor!
Old 1/25/06, 06:52 PM
don_w's Avatar
That's good news Rich!! And a very nice gesture on your part as well with the tip. Kudos to you. I paid about $400 in labor for my install, so you're right there too. Now, go drive the crap outta of it!! hahah
Old 1/25/06, 07:00 PM
3rd Times A Charm
S197 GT's Avatar
Alright Rich! So, let's hear more about your opinion on the gears...Oh wait, he's probably still tearing them up!!!
Old 1/25/06, 07:22 PM
GRAYPNY's Avatar
I haven't gotten on it yet because I want to put a couple hundred miles on them first. I can tell you that I like these gears alot. It seems to be perfect for the 5 speed manual and instead of 3rd around town I'm in 4th so I don't see a downside to gas mileage. Also the rpm range is always in the 2100 range where there is no drone from the Borlas and 70 miles per hour looks to be about 2300 rpms where the Borlas are almost quiet. These 5 speed manual transmissions seem to have a fairly tall 5th gear and I actually like it better at 2300 rpms than the 2100 it ran at before.
Old 1/25/06, 07:25 PM
atomic_il's Avatar
dangit. 3-400$ for an install??? dangit.
i need to become a mechanic so i can make this kind of money
Old 1/25/06, 07:31 PM
tom281's Avatar
Cool, and congrats. Thanks for the info thats my next mod.
Old 1/25/06, 07:51 PM
Valentino's Avatar
Originally posted by atomic_il@January 25, 2006, 8:28 PM
dangit. 3-400$ for a install??? dangit.
I'm a mechanic and I don't make that kind of money
this place says they do Mustang gears for $299, although it also says rear discs cost extra so I'm not sure how much it would be for you '05 guys
http://www.performancespecialties.com/default1.htm
I can tell you that the Mitchell automotive labor guide book calls for 4.4 hours of work to do a ring and pinion removal and replacement on an '86-'04 8.8 rear end... for whatever thats worth
Old 1/25/06, 07:57 PM
Torrence's Avatar
Glad it all worked out.
Old 1/25/06, 08:22 PM
outdoorstom's Avatar
Glad to hear they got 'em set right for you. I knew you'd like them!
Old 1/25/06, 09:42 PM
wild stray's Avatar
Glad it all worked out for you. Too bad it took two trips but it's good to know your shop hung with the problem til it was taken care of properly. It's always nice to know you have a shop around that knows you, and that you can trust!
Old 1/26/06, 10:05 AM
05-1947's Avatar
so what was the reason for the original whine? Was the backlash too tight?
Old 1/26/06, 07:14 PM
u-got-stang's Avatar
Glad to hear it worked out for you... I have an appointment next Wednesday to get mine installed... If you still have a copy of the install sheet Dustin sent to you, I would love to get a copy of it, just in case....
Old 1/26/06, 07:21 PM
GRAYPNY's Avatar
I sent you an email. Good luck!
Old 1/26/06, 08:40 PM
Thanks Rich... Got it!
Old 1/26/06, 08:43 PM
dcranford's Avatar
Could I get that document too? I am ordering my 4.10s soon as well and would like to give this to the guys and have it done right the first time.
Old 1/26/06, 08:47 PM
GRAYPNY's Avatar
You've got mail!
Old 1/26/06, 09:57 PM
blackened's Avatar
Originally posted by GRAYPNY@January 26, 2006, 9:50 PM
You've got mail!
mind sending it to me as well? pm me and i'll reply w/ my e-mail. i've got whine right now and would like to see what those specs say. also what specifically was your issue?
thanks much!
Old 1/26/06, 10:01 PM
GRAYPNY's Avatar
I don't think this should be an issue so here is the link.
http://www.fordracingparts.com/download/in...-4209-G410M.pdf
Old 1/27/06, 07:40 AM
Spider's Avatar
Ok, this sounds great, what do I need to know or do to get this adrenalin mod on my car.... Thanks for any help guys.........
Old 1/27/06, 09:04 AM
blackened's Avatar
thanks for the link gray. do you know exactly what was wrong with your set up the 1st time? too much lash? in my situation the tech told me specifically he set mine up at .013" and later i found in another tech doc that it should be between .008 and .010
Quick Reply: 4:10 Gears Installed Today - Part ll
