4.10 Gears and Girdle
Old Aug 22, 2005 | 06:07 PM
pittperson's Avatar
The topic says it all. My shop suggests that I get a beefed up girdle when I have my gears installed. What do you guys think? yay or nay? I'm not a weekely drag racer, just once in a while.
Old Aug 22, 2005 | 06:17 PM
169stang's Avatar
If you do, you'll need to relocate the panhard bar with a (BMR fabrication) bracket like the one shown in order to clear the girdle, or you will have to grind down the girdle and the panhard bar for it to fit. It will still rub under hard exceleration if you choose to grind. A girdle is just extra security. If you go to the track for an occasional run, a girdle may be overkill. It really depends on what tires and how hard you run it.
http://www.bmrfabrication.com/2005Mustang.htm
Old Aug 22, 2005 | 07:28 PM
don_w's Avatar
OK, David... I'll bite. What exactly is the benefit of the girdle?
Old Aug 22, 2005 | 09:59 PM
169stang's Avatar
Yea, that's what I was going to say! Sorry I didn't elaborate. I knew the carrier wants to push outwards and the girdle will keep that from happening. I just have to get better at answering more technically as opposed to what else you would need. I go through things and try to help others avoid doing what I do. I.E. If you pull the tranny, you'll need to jack up the front of the motor...the tranny comes out much easier. Of course this was my first tranny extraction, but it'll be a hellava lot easier next time! When I put my girdle on I had to grind it down a bit as well as the panhard bar. Now there is a bracket available and would reduce the headscratching. :scratch:
Old Aug 22, 2005 | 10:39 PM
don_w's Avatar
Thanx again, guys!!
Rando
Aug 25, 2021 11:12 AM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
