4.10 Gears as a Daily Driver
Old 12/30/05, 01:37 PM
  #61
wild stray's Avatar
You will have to adjust your rpm downward somewhat for a hard launch, but excess tire spin is not a given. With low profile tires, 285's, a hard launch is at 1800 with a very slight slippage. I would guess this would be pretty close with stock tires.
Old 12/30/05, 05:05 PM
  #62
Clem's Avatar
Originally posted by max2000jp@December 30, 2005, 2:29 PM
Spin thru first?
Yes!
With the 4.10's and my Fuzion 255/50's I rarely get traction in 1st. Forget hooking up on a cold day.
From a roll in 2nd at 3500 rpms or so I can occasionally break them loose.
The other night, with some serious cold air pulling through the JLT, I went sideways yanking 3rd! Wintertime traction blows! :shock:
I don't think I would have a prayer at the track without DR's.
Old 12/30/05, 06:11 PM
  #63
GRAYPNY's Avatar
It seems like I am only in 1st gear for a moment before I shift to 2nd. I can't imagine running 4:10 gears BUT I'm seriously thinking about going for it.
Old 12/30/05, 06:20 PM
  #64
clockworks's Avatar
Just do it. To be perfectly honest, I have 4.10's, CAI, tune, TBS....and my car feels like a dog. At first it feels fast, but then you get used to it and then you wished you'd gone even steeper...
Old 12/30/05, 06:23 PM
  #65
GRAYPNY's Avatar
OK a couple of stupid questions.
1. Will I need a retune?
2. How much will this screw up the speedo?
Old 12/30/05, 06:27 PM
  #66
tom281's Avatar
Yes, you will need a retune, which will fix your speedo.
tom281
Old 12/30/05, 06:50 PM
  #67
wild stray's Avatar
I am sure Breenspeed will fix you up! Bama Chips took care of mine.
Old 12/30/05, 07:06 PM
  #68
Cleveland's Avatar
I went through a few gas tanks with the speedo/odometer reading off before having DTP redo my entire tune for me.
-Dan
Old 12/30/05, 08:01 PM
  #69
GRAYPNY's Avatar
Why would you need to retune? My Xcal is the basic model and I don't think you can correct the speedometer with this model. I wouldn't be changing the A/F ratio so how would the 4:10 gears change the current computer flash?
Oh well, I sent an email off to Brent and I'll see what he says!
Old 12/30/05, 08:22 PM
  #70
Cleveland's Avatar
A tuner has to recalibrate it for you for everything to read correctly.
-Dan
Old 12/30/05, 08:27 PM
  #71
wild stray's Avatar
The lower ratio will give fits to the torque management and you will go into putt home syndrome. Your tuner will fix you right up.
Paul
Old 12/30/05, 08:33 PM
  #72
GRAYPNY's Avatar
Thank you for the info. Is this a great site or what?
Old 12/30/05, 08:37 PM
  #73
wild stray's Avatar
[quote=GRAYPNY,December 30, 2005, 7:36 PM]
Old 12/30/05, 09:30 PM
  #74
don_w's Avatar
Originally posted by wild stray@December 30, 2005, 12:22 PM
IMO, get them thru the shop that's going to do the work.
+1... that's what I did.
Old 12/30/05, 09:36 PM
  #75
don_w's Avatar
Paul
I don't feel that is entirely true. I didn't have a custom tune until 2 or 3 months after I got my gears installed. I just used my old Predator to reset the speedo, but did not change the tune at all. It ran just fine. But, once I got Doug's torque tune and the X2, I couldn't hook at the track with my street tires anymore... had to get the drag radials. And remember... I have an auto trans.
Old 12/30/05, 09:44 PM
  #76
Cleveland's Avatar
Paul
I call BS on your torque managment causing a fail safe condition and here's why....
I can say that it never messed with mine over the weeks that it needed the retune, I even brought it to the track for plenty of full throttle fun.
-Dan
Old 12/30/05, 09:51 PM
  #77
GRAYPNY's Avatar
Well I am kind of an automotive nerd but what does torque management have to do with a 5-spd manual?
Old 12/30/05, 09:58 PM
  #78
wild stray's Avatar
-Dan
http://forums.bradbarnett.net/index.php?sh...ndpost&p=548139
Old 12/31/05, 12:00 AM
  #79
SixtySix's Avatar
Of course if it doesn't happen to you, Dan, I guess it's just not possible that anyone else could have a problem.
How's that shoe leather taste these days
Old 12/31/05, 02:10 AM
  #80
Cleveland's Avatar
Originally posted by wild stray+December 30, 2005, 9:01 PM--><div class='quotetop'>QUOTE(wild stray @ December 30, 2005, 9:01 PM)</div><div class='quotemain'>http://forums.bradbarnett.net/index.php?sh...ndpost&p=548139
[/b]
<!--QuoteBegin-Doug904
@October 30, 2005, 12:42 PM
The code is a throttle issue, ......
I'm pretty sure I know what the issue is as alot of SCT dealers still don't have access to the electronic throttle adjustment they are leaving out a major part of the programming and causing some cars to go into limp mode when they upgrade gears.
thanks, Doug.
BamaChips@gmail.com
[/quote]
From what I read back then and now.... IT WAS A THROTTLE CONTROL ISSUE, NOT TORQUE MANAGEMENT.
Try linking a thread that would offer a credible backup to your original BS comment since you cant come up with something on your own. Or, you can admit to using the incorrect terms or whatever and I can let it go.
No foot in my mouth here until you can show me that Im wrong. You just dont make sense to me SixtySix, you stand behind someone that offers no answer or any real experience in the matter. Get bent for that leather thing.
Show me somebody that has had a torque management issue from moment 1 that followed the installation of a numerically higher gearset with no other mods. I havent seen a single issue come up anywhere besides to Mr. Mikem and after many many miles of driving with the gears in place.
A bad tune can cause whatever issue you want up to and including termination of an engine but it doesnt seem (in my experience) that by simply installing a numerically higher gearset is something thats going to confuse the computer during normal driving. The only thing that makes sense is reading the speed incorrectly on the speedo, this also incorrectly logs your drive miles for your trip and odometers. Further modifications and improper tunes can lead to the fail safe as with any mod and imcorrect tuning. Go figure.
Im only fighting for the fact that installing a different gearset BY ITSELF only needs a retune to correctly read the correct speed of the rear wheels. Its not even a tune, its more of a recalibration since only one figure needs to be modified. A change in the multiplication/division factor from 3.3 or 3.5 to 4.1.
-Dan
Quick Reply: 4.10 Gears as a Daily Driver
