3.73 vs 4.10 gears
Old Aug 10, 2005 | 10:39 AM
clockworks's Avatar
I kinda want to get gears for my new Stang. I read the thread on fuel economy with 4.10 gears. Sound nice, sounds like yall really like them.
My buddy, who used to be really into modding his Mustang, said he thinks 4.10 are a bit too much and I should look into 3.73. What do you guys think? Would it be worth it? What are the pros/cons of each?
What are the tops speeds like for each gear when using 3.73 vs 4.10?
I'm getting less concerned with fuel economy, because like someone said, you just end up driving in a gear higher than normal when cruising.
Also, what is a good internet site to buy performance parts for a 2005+ Stang?
Seeing as how I'm a newbie to this stuff, please feel free to be as detailed as possible in your answer.
Thank you for the info an opinions.
Old Aug 10, 2005 | 10:55 AM
Weedo's Avatar
I'm running 4.10's with my Auto/Paxton setup and couldn't be happier. If I had the manual, I probably wouldn't go with the 4.10's. In "normal" driving, my auto shifts into 2nd at about 7mph, shifts into 3rd at about 15mph, and into 4th at about 23mph. All smooth and effortlessly. Now if I had a manual, there's no way I'd want to shift that much. Then again, you can skip gears, take off in 2nd, etc...
My opinion is 373s for a manual "daily driver" and 4.10's for the auto.
Old Aug 10, 2005 | 11:05 AM
Ranger's Avatar
I'm going thru the same thought process. Been told by more than one person that the 3:73 is a good all around choice but that I might as well keep the stock 3:55 since the difference does not justify the cost. Ford does not have them (I don't think) but you can get 3:90's etc from other suppliers.
Old Aug 10, 2005 | 11:27 AM
SP_51-F1's Avatar
Hey clockworks, fancy meeting you here.
I've been debating the same thing. If I choose to change gears, I think I will go with 3.73 on my manual.
Did you order an auto or manual tranny?
Old Aug 10, 2005 | 12:05 PM
pittperson's Avatar
Great guys, thanks! Now I don't know what I want, I was almost ready to go with 4.10s now I have to consider 3.73s...
as a side note, the shop that I talked to tried to talk me into 4.30s for the same price as the 4.10s
Old Aug 10, 2005 | 12:32 PM
eighty6gt's Avatar
Get the 4.30's.
http://www.f-body.org/gears/
This will allow you to calculate your RPM's at varying speeds.
Input your tire size... listed below are the gear ratios.
Manual: 1st 3.38, 2nd 2.00, 3rd 1.32, 4th 1.00, 5th .68
Auto: 1st 3.22, 2nd 2.29, 3rd 1.54, 4th 1.00, 5th .71
Old Aug 10, 2005 | 01:05 PM
don_w's Avatar
I don't see any reason to go with 3.73s... you'd never notice the difference (especially with a manual), but you'll pay just as much for them as if you went with 4.10s.
Old Aug 10, 2005 | 01:48 PM
Weedo's Avatar
I think I have to agree with Don. Going from 3.55's to 3.73's doesn't seem worth the money/time to do it. But I'm not sure I'd go with 4.10's in the manual. Actually, who am I kidding, I'd "grin and bear" the pains of shifting too much just to make the car quicker! Some of the quicker N/A DOHC guys go with 4.56's...
Old Aug 10, 2005 | 02:10 PM
mikem's Avatar
I love my 4.10s.You can cruise right up to 80mph and not brake 3,000rpm,s This is with a 5spd.Car even pulls hard in forth when I get aside of something interesting.First gear is just about useless .3.73s are definately not diferent from stock.
Old Aug 10, 2005 | 02:22 PM
pittperson's Avatar
My GT is my only car. Would it be tough to deal with the 4.10s in the winter time? Would I just have to take off in 2nd gear or would my car be useless?
Old Aug 10, 2005 | 04:19 PM
clockworks's Avatar
Originally posted by SP_51-F1+August 10, 2005, 11:30 AM--><div class='quotetop'>QUOTE(SP_51-F1 @ August 10, 2005, 11:30 AM)</div><div class='quotemain'>Hey clockworks, fancy meeting you here.
[/b]
I was wondering when you were gunna say hi...
<!--QuoteBegin-SP_51-F1
@August 10, 2005, 11:30 AM
[/quote]
Manual, of course. I'm one of those people who's adamant about getting MT in a sports (err, muscle) car.
Ugh, this is too hard. The two camps are split right down the middle it seems: 3.73 are perfect for a daily driver vs. you won't notice any difference with 3.73's
Old Aug 10, 2005 | 04:34 PM
eighty6gt's Avatar
With 4.30's you'll be fine, just run winter tires at all four corners. You might want to launch in second, I think I launched in 1st quite a bit with my 5.0 in the winter, with 4.10 gears and shorter tires.
Old Aug 10, 2005 | 05:05 PM
Clem's Avatar
Come on Chris, you're 23 and that's old guy talk. I should know, I'm one at 41. Like I said before, if not for my gear noise, I'd be ecstatic about my 4.10's. As it is I only love them. Unless you're running up and down I-95 all day I think you'd love them too.
I don't think you'll have any real problems in winter seeing as we don't get that much bad weather around here. That's easy for me to say, I've never even driven mine in the rain. I have an '04 F-150 4x4 for those days.
Sometimes I do take off in second gear, but only if I'm on a slight decline. Uphill you come too close to slipping the clutch for my taste. I'd bet that it's quite possible in the snow. Someone other than me would know better.
Old Aug 10, 2005 | 06:27 PM
97svtgoin05gt's Avatar
After tossing this issue around in my head for some time, I've decided to stick with the stock gears. With the older cars, going from 3.08s or 2.73s was a no brainer. I had 3.73s in my '97 Cobra and it was beautiful. My car wasn't a track car and the 3.73s really woke the car up. With this one, there really isn't going to be any difference performance wise with a change from 3.55 to 3.73s. The money will be better spent elsewhere. I'm not into the 4.10s. Guys who frequent the track, by all means. That's the way to go.
Old Aug 10, 2005 | 06:46 PM
wild stray's Avatar
The 4.10's are a very sweet ratio for the manual in this car. If you want to wake up your pony without being harsh, go with the 3.90's or 4.10's.
Old Aug 10, 2005 | 07:18 PM
pittperson's Avatar
You're right, what was I thinking. 4.10s it is....
I do do a lot of driving for work, any from Wilmington, DE to northern VA, but I'm young, I can live with that!
Old Aug 10, 2005 | 08:35 PM
outdoorstom's Avatar
There's a post here that an automatic trans with the 4:10's shifts from 1st to 2nd at 7mph and 2nd to 3rd at 15 mph. For you guys with 4:10's and manual transmissions, approx. at what speed do you find yourselves shifting during normal driving conditions? Thanks!
Old Aug 10, 2005 | 09:20 PM
wild stray's Avatar
Just had mine out.....15, 25, 35 prox.......and 105
Old Aug 10, 2005 | 09:27 PM
pittperson's Avatar
I like that 4th to 5th number Paul
Old Aug 10, 2005 | 09:35 PM
wild stray's Avatar
Yeah, it woulda prolly been higher, but I was passing a sub-station. :cop:
