3.73 over 4.10...Lidio recommends?
Old Oct 13, 2006 | 03:24 PM
tw0scoops123's Avatar
I think I read on more than a few posts that Lidio at Alternative Auto has convinced guys that were thinking about getting 4.10s to get 3.73 gears. Is this true? And what was his reasoning?
Old Oct 13, 2006 | 03:49 PM
Monolith's Avatar
amyb from Shelby also mentioned in a post that they had a 4.10 around and that she preferred the 3.73. (Shelby GTs will have 3.73's).
Old Oct 13, 2006 | 05:05 PM
Doug@C&L's Avatar
If you have an auto go with 3:55 or 3:73's, the 4.10's dont work well with our 2-3 gearing. I know, I had them in my car and it was bad at WOT.
Old Oct 13, 2006 | 06:52 PM
GRAYPNY's Avatar
I think the perfect gear for the 5 speed manual would be a 3:90!
Old Oct 13, 2006 | 07:12 PM
SONICBOOST's Avatar
What do our car's come with 3:55?
Old Oct 13, 2006 | 07:38 PM
3.55 manual, and 3.31 auto I think.
Mine is a manual so I was thinkin' 3.73 maybe. I do drive 70 miles a day for commuting. But I need another performance mod besides the intake and tune. I can't do the exhaust, cuz I have it just loud enough.
Old Oct 13, 2006 | 07:42 PM
HiRoller's Avatar
I got the 4.10's after Lidio's tune. He wouldn't help me once I put in the 4.10's.....because "he didn't like 4.10 gears" .... thanks to DOUG I'm fine now.... I luv the 4.10's....
Old Oct 13, 2006 | 08:50 PM
korinwoodo's Avatar
thats kinda....a good way to lose business i geuss
Old Oct 14, 2006 | 08:32 AM
Why doesn't he like the 4.10s? Just cuz they don't work well with his tune?
Old Oct 14, 2006 | 08:40 AM
Doug@C&L's Avatar
Yeahn now that's one thing I dont do. I give suggestions and recommendations, Not Rules. This is your car and you can do as you like with it. I'll support you if you put 2.73's back in it.
Old Oct 14, 2006 | 09:19 AM
Sonic Thunder's Avatar
Does anybody have the 3.90's and do you like them???
Old Oct 15, 2006 | 04:03 AM
68wanabe's Avatar
I have 4.10's and Doug's torque tunes and I love it. I can break the tires loose in 1st, 2nd and 3rd gears. The car is awesome!
Old Oct 15, 2006 | 08:21 AM
I don't wanna be able to break the tires loose. Just slows me down. Should I go with the 3.73s then?
Old Oct 15, 2006 | 07:59 PM
spyder7724's Avatar
i took the 3.73's out and went to 4.30's and picked up .15 and 3-4 mph!!! heck once i get the tune adjusted for my converter i may step down again. i don't drive much on the street but the 4.30's are fine cruise 70mph at 2600rpms. i'm thinking of 5.14 or 4.88 depends on what size tire i get next. if i go with a radial slick 9x30 i may go 5.14 or higher(numerically). the steepest gear i've found is 6.14!!!!yahoo 1/8 mile gears
Old Oct 15, 2006 | 11:45 PM
Redfire 05Gt's Avatar
Don't forget, he's got an auto with CAI and Doug's 93 octane torque tune and a couple other bolt-ons! I don't think by "breaking loose" he means "out-of-control never-ending tire spinning", or does he? You already have 3.55's so 3.73 isn't that much of a change, but maybe that's all you want. There's also 3.90s to consider, just not from FRPP.
The general consensus (but not the rule) seems to be 4.10's with a normally aspirated 5 spd is optimal, and 3.90 or 3.73 with a power adder; for automatics, 3.90 or 3.73 for NA and 3.73 (or even 3.55's) with a power adder.
Old Oct 16, 2006 | 08:47 AM
I know it's not much of a change, but I don't want to go too far to the point where I'm dreading my commute.
Old Oct 16, 2006 | 09:03 AM
harleybill's Avatar
The 3.73 is perfect for the inbetweener of drag and highway. If you don't do a lot of highway driving then the 4.10 is better for the drags and won't totally kill you on the street....If your not really going to race at the strip, go with the 3.73's and you will be totally happy. The 3.73 is probably the best of both worlds for the current stang.
Old Oct 16, 2006 | 11:02 AM
Keystone's Avatar
Some very stange posts here, which do not agree with my experiences. I talked to him (Lidio) a little over a year ago and here's what he told me regarding the 5 speed manual cars:
1) 3.73 isn't enought of a difference from the 3.55s to be worth the expense of the swap.
2) the 3.90 gear sets are noisy and not a good choice for a street driven car.
3) 4.10s work very well with the 5 spd. manual gear ratios and that was his recommendation.
I went with the 4.10s and couldn't be happier.
Old Oct 16, 2006 | 11:11 AM
Did he recommend them maybe to Manuals and not auto's?
What kind of driving do you do?
reply to: "1) 3.73 isn't enought of a difference from the 3.55s to be worth the expense of the swap."
What about the costs difference to the wear on the engine vs the performance?
Old Oct 16, 2006 | 11:27 AM
metroplex's Avatar
I've been considering 2.73s for better gas mileage...
