3.55 to 3.73, is it worth it?
Old Nov 11, 2008 | 07:11 AM
MaverickMLFD371's Avatar
I'm running out of mod to do the stang! the mod bug kills me, LOL.
considering I've maxed out the HP potential on my stock motor, I'm looking for an alternative performance addition to the stang.
Someone brought up the idea of gears. I'm running 3.55 gears, people have told me to go 3.73 or 4.10. and yet again its a back to back battle, some say 3.73 you won't feel any difference from 3.55, and 4.10's are way too much for a s/c manual.
help! what do you guys consider for a whipple s/c manual?
Old Nov 11, 2008 | 07:17 AM
dustindu4's Avatar
9 is not my lucky number.
lots of people drive around with 4.10s with more power than what you have. Personally I would not step up to just a 3.73 because the small increase in ratio is not worth the cost of having gear noise from popping the cherry on your factory rear end. It will be more aggrivation than it's worth.
Old Nov 11, 2008 | 08:00 AM
classix_stang289's Avatar
Im not sure what company, but there is a oddball ratio of 3.90's. Maybe richmond?
Old Nov 11, 2008 | 08:01 AM
Five Oh Brian's Avatar
A whippled GT makes plenty of low end grunt since you get boost at low rpm's, so gearing won't really make a big difference like it would in a N/A car, or one with a turbo/centrifugal. I would suggest keeping the 3.55's and spending that money on a different mod that better compliments your whipple's low end grunt.
Old Nov 11, 2008 | 08:26 AM
like what?
Old Nov 11, 2008 | 08:34 AM
Torrence's Avatar
Go 4.10's! They are awesome with the WHIPPLE. Absolutely no regrets... None.. I thought the car was fun with the WHIPPLE, but now with the 4.10's it's insane. lol
Old Nov 11, 2008 | 08:38 AM
I bet the traction is bad with the 4.10s?
aren't you from jersey?
Old Nov 11, 2008 | 08:54 AM
Torrence's Avatar
I'm from Jersey.....
I have no traction issues. Just pull off a little slow and I have a ton of suspension mods + sticky tires so I love driving this thing. I thought the car was quick before, but now it's just ridiculous. lol
Should have installed the 4.10's a long time ago. I had 3.90's, but they wined too much and had the 4.10's installed. You will not regret it.
Old Nov 11, 2008 | 09:07 AM
dustindu4's Avatar
IF you're doing any kind of gear swap, consider either having a truetrac diff put in, or replace your carbon fiber clutch packs when you do your gears.
Old Nov 11, 2008 | 09:59 AM
jjw368's Avatar
Don't waste time and money on 3.73...4.10 all the way. Just make sure you get the computer changed (most tuners will do it) so that you know what they are pulling you over for!
Old Nov 11, 2008 | 10:02 AM
Error404's Avatar
I had 4.10s when my manual transmission went into the car. I think 4.10's are to much for a manual transmission supercharged car, at least for me anyway. I liked them with the automatic, but didn't like them with the manual. I went back down to 3.55s and I like them better. But relating to your question, I don't think a jump from 3.55 to 3.73 will be much noticeable. Probably about the biggest thing you'll notice is a slightly higher cruising RPM?
Old Nov 11, 2008 | 05:04 PM
Rays197's Avatar
IMO if you are going to see some track time with your car then go with the 4.10. If not why spend the money to chance a problem. Have you considered go with a new Drive Shaft to reduce some weight??
Old Nov 11, 2008 | 07:35 PM
metroplex's Avatar
I kind of wish my GT came with 2.73s so I could drive normal highway speeds and keep the RPMs below 2k.
Old Nov 11, 2008 | 07:49 PM
i'm already shafted with the coast d/s
Old Nov 11, 2008 | 07:57 PM
Indystang's Avatar
2.73 Gears
My 86 GT had 2.73s stock from the factory and it would show 78 mph at 2000 rpms in 5th gear 225/60/15 stock size tires. I got about 27 mpg running 65-70 though.
Old Nov 11, 2008 | 11:13 PM
don_w's Avatar
This is a joke... right?
Old Nov 12, 2008 | 05:57 AM
JonCo's Avatar
Wrong choice of cars then if your worried about that
Old Nov 12, 2008 | 06:40 AM
Rays197's Avatar
How about a Livernois 298 stroker then turn up the boost. You could go with a set of their stage 3 heads but i wouldnt put the heads on boosted without a forged bottom end. No need to risk the heads on the stock bottom end.
Old Nov 12, 2008 | 06:44 AM
VAiN's Avatar
+1 on that... please tell us that's a joke.
Old Nov 12, 2008 | 07:55 AM
I bought my 89 Mustang 5.0L LX brand new with 2.73 gears and within 60 days had 3.73's installed as the 2.73's were absolute garbage! Car was much more enjoyable to drive with 3.73's. If you want super low freeway cruising rpm's, get a steeper overdrive ratio which only affects high gear, not all gears!
