285/40-18's in Front?
Old Jun 16, 2007 | 10:56 AM
65sohc's Avatar
Will 285/40-18's fit in the front? I know that Roush's come with 275/40-18's all around but the 285's are an exact match in overall diameter to the stock tire whereas 275's are somewhat smaller and leave a little more tire-to-fender gap. My car is lowered about 1.25 inches.
__________________
Old Jun 16, 2007 | 12:27 PM
howarmat's Avatar
They will fit even lowered as long as your wheels are the proper offset.
Old Jun 16, 2007 | 01:08 PM
jwgroovin's Avatar
__________________
I'm curious, what tire are you looking at in 285/40r18?
Old Jun 16, 2007 | 03:02 PM
howarmat's Avatar
http://www.tirerack.com/tires/Compar...15&RunFlat=All
Old Jun 16, 2007 | 03:45 PM
jwgroovin's Avatar
Now that's odd. My own search on the TireRack site only resulted in 5 returns. Thanks for this.
John
Old Jun 17, 2007 | 01:37 PM
65sohc's Avatar
Goodyear Eagle F1 Supercar
Old Jun 17, 2007 | 10:52 PM
official_style's Avatar
they fit.
Old Jun 18, 2007 | 05:45 AM
Infinity's Avatar
Originally Posted by official_style
they fit.
I was just about to mention your car. I bet it tracks like a mother, though. Still cool.
Old Jun 18, 2007 | 08:10 AM
max2000jp's Avatar
They will most likely rub when close to full lock. I have FRPP springs with 275/40/18's up front and they very slightly rub when the steering wheel is close to full lock.
Old Jun 18, 2007 | 09:37 AM
FLAstangx3's Avatar
Bump Steer Kit??? Lot of moola for those tires.
Old Jun 21, 2007 | 09:05 PM
not any worse then with the 255s. helps handling big time, i didnt like how it drove with the staggered 18x10 18x8 setup. im not lowering tho.
Old Jun 21, 2007 | 09:42 PM
eci's Avatar
eci
285 is asinine for the front imo. A Porsche 997 Turbo has 305 in back, 235 in front and has world class handling, and weighs about the same as a Mustang GT.
Old Jun 21, 2007 | 09:44 PM
well all i can tell you from driving on both, is the 285s up front make a huge difference in handling, i cant lower my car so i need as much handling help as i can get. looks 10 times better then any other setup i have seen too.
Old Jun 21, 2007 | 10:22 PM
max2000jp's Avatar
Like I said, 275's up front slightly rub the rub inner plastic fender under full lock. You only use full lock when parking or at slow speeds so it's not a big deal. Adding 10mm more width up front might cause rubbing during aggressive driving.
Old Jun 21, 2007 | 10:33 PM
i get no rub lock to lock, and no rub during extremely agressive driving.
Old Jun 21, 2007 | 10:37 PM
max2000jp's Avatar
What are your suspension mods?
Old Jun 22, 2007 | 10:42 AM
delurker's Avatar
Pics? My wallet feels a little too thick lately and I'm again (still) thinking about new wheels.
Old Jun 22, 2007 | 11:05 AM
05BlackGT's Avatar
If 285's are asinine, I must be crazy. I run 295's in front......and the camaro drivers still laugh at how narrow they are. You really can't compare tire widths between rear engine and front engine cars.
Old Jun 23, 2007 | 06:29 AM
Import-Slaya's Avatar
How much camber are you guys able to run with this setup? I'm assuming 10" wheels up front (17"?). How much clearance is there between the tire and strut?
I'd like to run 275's to 295's on all four corners and still be able to get -2 degrees using the Steeda billet adjusters, then use camber plates to get any additional camber needed for events.
Old Jun 23, 2007 | 07:45 AM
max2000jp's Avatar
I am running Roush 18 X 10's with 275/40 RE050A Pole Positions all around. My alignment for the street is -1.3 camber, 7.2 caster, and .03 toe'd in. I am also running FRPP springs, which lower the car roughly 1.5". My tires rub the inner plastic fender near the brake like fitting under full lock. It's not a big deal and I just need to cut some of it away and the problem will be gone. I can take pictures of the clearance and where it's rubbing on Monday.
