2005 gt cams
Old 9/25/12, 07:10 PM
s197gt's Avatar
Originally Posted by wallace
So you have the FFRP intake?! How do ya like it? I have the hotrod cams and looking to get supporting mods, I'm going w/ JBA shorties.
Already have 4.10 and jus about every bolt on possible, looking at getting the intake.
Yes i have the ford racing intake pretty gud hp gains and tq but the delete plates from steeda is cheaper and ive seen same hp and tq gains but im planning on super charging so thats why i got the ffrp intake its tested up to 2 bars of pressure, plus looks sick under the hood and doesn't soak in the heat stays cool even after hard driving
Old 9/25/12, 11:19 PM
dirtfan71's Avatar
Originally Posted by muscledom
Dude when you go to the track people flip. There aren't many s197s hooked up like ours driving around everyday. It's pretty cool.
I spent 20 minutes tonight talking with a kid in a Chevy pickup. I just stopped for gas but he was full of questions about the cams. I can't wait to get my BMR lca brackets on and back to the strip.
Old 9/26/12, 11:33 AM
muscledom's Avatar
Yea it's neat to see. Especially if you have full exhaust. It's ****in loud lol
Old 9/26/12, 08:10 PM
dirtfan71's Avatar
I currently have stock manifolds and cats with Flowmaster 40s. It rumbles great but I can't wait till this winter/spring when I add Kooks w/ catted H.
Old 9/27/12, 07:47 AM
s197's Avatar
I think I'm Going to go with the ***** thumpr cams I have pypes shorty headers off road x pipe and SLP loudmouth axle back exhaust and I put in 373 gears on my five speed do you guys think that gear is going to be steep enough for the ***** thumpr comp cam
Old 9/27/12, 08:30 AM
muscledom's Avatar
Everything sounds good except for the headers. Comp recommends longtubes. Makes a huge difference
Old 9/27/12, 08:52 AM
Agent MOO's Avatar
My mechanic's busy so I have to wait another week to get them installed... at least that will give me time to fix my rattling exhaust, with cams the problem would probably be much more pronounced
Old 9/27/12, 09:02 AM
muscledom's Avatar
Yea I have some rattles I need to fix myself lol
Old 9/27/12, 10:28 AM
Doug@C&L's Avatar
Comp cams do make the better power of the two but require limiting or as I used to Locking out the cams. This may impact economy but truly both of them at idle are going to be a little agressive on mpg.
Still, I've tuned and installed FRPP cams, even in a 11:1 engine with Stage 3 heads, and they work well and with the stock limiters. This in turn makes for a easy install without removing the timing cover, if you goto a mechanic that knows how to work on a 3-valve.
Either require tuning, and the cams accent additional mods like LT headers, CMVC deletes and/or intake manifold. You wont go wrong with either.
Thanks, Doug
Old 10/7/12, 08:03 PM
Agent MOO's Avatar
Got my FRPP hotrods in and they are awesome. Shakin' around something fierce with the poly motor mounts. Low end torque loss seems really minor. Only noticed it when I put it in reverse and it required a higher RPM to keep from dying
Old 10/8/12, 06:28 AM
muscledom's Avatar
That's awesome man! Glad you like em! I'm sure your flywheel makes the loss in torque less noticeable since you have to rev higher anyway. Watch how your antenna wiggles now lol
Old 10/9/12, 10:33 PM
Agent MOO's Avatar
Here's a quick clip of my FRPP Cams with flowmaster AT's
Old 10/10/12, 07:14 AM
muscledom's Avatar
Video Link: http://www.youtube.com/watch?v=vtJONalY1DU
Sounds nasty dude. Props
Old 10/10/12, 06:03 PM
FRPP Hotrod Cams Idle - YouTube
love it but your muffler tip needs to be adjusted
Old 10/10/12, 06:50 PM
Agent MOO's Avatar
The MRT H-pipe is a bad fit, I have to angle it that way to keep the overaxle pipe from banging into the panhard brace.
Old 10/11/12, 09:17 AM
ic see well that makes me a little sad.
Old 10/11/12, 09:36 AM
Agent MOO's Avatar
I'm going to try the CHE panhard brace and that might fix it
wallace
3/29/16 10:09 AM
Quick Reply: 2005 gt cams
