16 inch drag wheels?
15's wont fit.
Im running 16's for the rear, nothing needed to be altered. I Havent track tested them yet If U scroll back a few pages, you'll find a thread I posted some pics in with 16x7's, there was little to no interest in it.
I will try them once as is, and then ship them off to have them widened to 16x9's. Otherwise they slap right on, no issues.
Guest
Posts: n/a
Oops. I forgot about the 3" wheel studs you have to use. No-one makes a 3" wheel stud for the 05 yet. I had to open up the holes in the axles and hubs to fit the older designs.
The axle holes were .600 dia I had to open them up to .615 to use Moroso wheel studs #46180
The hub holes were .535 I had to open them up to .580 and use Moroso wheel studs #46185
I had to use these 1" slotted cloth discs in a 1/4" mandrel with a 22,000 RPM die grinder, and a dial vernier to measure the holes.
