13.02@104mph Video. (3rd gear help?)
Old Apr 27, 2008 | 11:58 AM
GOarmy08's Avatar
Sorry bad SQ and there's a monster railcar burnout out mid way through. This is my first time at the track... This is also the 6th of 6 runs completed in about an hour and a half. So the car is definitely heatsoaked. I missed third with the Hurst shifter twice on this day... It seemed fine for the first run, but the others it seemed loose and hard to fully put in the third slot. I'm going to get underneath the car and tighten up the peices soon and hopefully that'll fix the problem. If not I'm thinking CHE brackets or even MGW...
60-ft was about a 1.87 on this run. And launched at about 4,400-4,500 rpms. There was some wheelspin, but that was good in this case with the 3:31 gears (other launches with less wheelspin yeilded 1.9s). 3rd gear sounded like it hit fuel cut off at around 5,700 rpms because I'm pretty sure I was running out of gas... lol.
I wasn't out there to cut a mean light, so don't gig me on that.
http://www.youtube.com/watch?v=H38oYsJoeIY
Any 60-ft tips or comments are welcome... more details are in the link on the right side of the page.
Old Apr 27, 2008 | 01:05 PM
2kanchoo's Avatar
I had major problems with my hurst shifter binding under powershifting conditions. I can tell you that you won't have that problem with the mgw.
Some 4:10 gears would help. You could launch at 4500 with them and a bit of easing on the clutch. That with an aluminum d/s would help getting the power to the ground quicker.
Your sig says you have a sct xcal 2. What do you have your rev limiter set to? I would suggest setting it to 7000. That way with 6400 1st and 2nd gear shifts you can redline 3rd gear as you trap instead of needing that 3-4 shift.
Old Apr 27, 2008 | 01:16 PM
DarkFireGT's Avatar
Heck, I had that type of thing happen with the stock shifter in both cars. You need motor mounts or torque limiters (both would be best).
Old Apr 27, 2008 | 03:50 PM
GOarmy08's Avatar
2k... I have the rev limiter set to 6,500 right now... I'm can run through the traps in 3rd gear, but I hit fuel cut-off (or something) at the top of third, so instinct told me to shift into 4th to keep the car moving. I'm not quite sure where I'm shifting for the 1-2 shift, I didn't look down... I shift more by feel if the car is pulling through the rpm band or not.
I'm considering these limiters here... http://www.cheperformance.com/cartge...pid=208&cid=15
Anyone have any experience with these?
edit: here was the timeslip numbers...
R/T- .734
60'- 1.879
330- 5.405
1/8- 8.347
MPH- 83.34
1000- 10.873
1/4- 13.022
MPH- 104.80
Old Apr 27, 2008 | 11:16 PM
2kanchoo's Avatar
R/T- .734
60'- 1.879
330- 5.405
1/8- 8.347
MPH- 83.34
1000- 10.873
1/4- 13.022
MPH- 104.80
I've heard the TB starts to cut out a few hundred rpms from the rev limiter that might explain the feeling of needed to hit 4th. I'd suggest raising it to 7000. Just cause it's that high doesnt mean you need to let it hit that high. This will also allow you to still trap in 3rd gear if you decide to throw a set of 4:10 gears in it. Shifting at about 6300-6400 1 to 2 and 2 to 3 then letting it ride out should get you into the 12's atleast. 4:10's, an aluminum d/s, raising the limiter to 7000, good 6300-6400 shifts, and atleast the same 60' time, would make get you 12.7-12.8 easy.
Old Apr 29, 2008 | 12:29 PM
GOarmy08's Avatar
Sorry, I couldn't really find a Timeslip/Drag Racing category, and it ended up being a GT mod's type thread.
With the 3:31s I can trap in 3rd gear without raising the rev limiter anymore. With 4:10s I know I'd easily hit 12s, but I'll keep the 3:31s because I'll be adding FI later on. If I give the car a good cool down, I'll hit 12s with ease I'm pretty sure.
Anyone have any before/after experience with the torque limiters for the 3rd gear shift?
Old May 2, 2008 | 02:13 PM
mot250's Avatar
So are you saying crossing the line in 3rd gear with 4.10's is possible in the 1/4 mile? I've been afraid to hold 3rd gear with 4.10s. Limiter set to 6800 with my SCT II. I used to do just that (cross the 1/4 mile in 3rd) with my stock 3.55's and that was my only complaint about my switch to 4.10s. I love my 4.10's for street, autoX and road coarses but 1/4 mile kind of left me bummed due to shifting up to 4th.
Gives me something else to try next time I hit the local 1320.
Old May 2, 2008 | 02:42 PM
tom281's Avatar
Not possible when you're blown atleast.... I am forced to shift into 4th with a blower and 4.10s.
Old May 3, 2008 | 06:51 AM
2kanchoo's Avatar
Yup. I shift at 6300-6400 1-2 and 2-3, and with my rev limiter at 7000 I redline at 110ish mph.
Old May 3, 2008 | 09:21 AM
jwgroovin's Avatar
Third gear was a problem for me too with the Hurst, but it DID improve some when I got a tubular kmember with the integrated motor mounts. But, shifts were still getting missed from time to time so I plunked down the cash for an MGW, and will hopefully get to the track next weekend or the weekend after next to try it. Right now I'm waiting on a metco driveshaft loop as my BMR loop kept smacking into the MGW shifter, at least where I have it sitting (at the middle set point)...we'll see.
John
Old May 3, 2008 | 11:30 AM
mot250's Avatar
Cool, I might give it a shot next time.
Old May 3, 2008 | 06:50 PM
GOarmy08's Avatar
thanks for the helpful replies guys, but I found the main problem I was having when I put my car up in the air yesterday... the front mount (the one closest to the front bumper) was backed out about a 1/2" causing the shifter to have too much play and jamming up 3rds slot at high rpm. Tightened it up and I can jam it pretty easily now. 3rd gear is still a little faulty (like John said), but I think that is just a Hurst defect from the factory on these shifters.
Would have had 12s today at Bremerton but it was rained out! I hate NW weather!!
Old May 6, 2008 | 03:04 PM
GT Bob's Avatar
There are several different rev limiters in the Spanish Oak processor..and raising one to 7K won't do a bit of good unless you raise ALL of them... and I don't think the handheld SCT's will alllow you to touch them all..
Rando
Aug 25, 2021 11:12 AM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
samjluck
Sep 17, 2015 10:24 PM
Cdvision
Sep 5, 2015 05:22 PM
