1/4 mile times
2005 GT coupe. MANUEL
Mods:
93 octane performance tune by diablo
WMS ram air intake
JBA shorty headers
What is ideal launching RPMS for my manuel? Do I feather the launch or dump it? Mostly what rpms should I be launching at? and for 1st-2nd i get crazy chirping any ideas to help?
Temp was 48* High humidity, 5 miles from track was rain, but they say it didnt rain on the track. I dont believe my tires were hooking.
Stock pirelli tires Stock psi
Best run of the night...
60ft-2.064
1/8 - 8.824
1/4 - 13.582 @103.30
Every run thereafter was 13.6 n 13,7s
60ft were consistent at 2.3....
I think the track sucked for every car, there was a 6.0L GTO there that ran 13.7 and he had some slicks on. also an auto 05 GT that was running 14.6's ouch. any ideas?
Tried lowering the psi in back to 17 and front to 25 think that made it worse.... I'm launching at 2,000
Mods:
WMS ram air intake
JBA shorty headers
60ft-2.064
1/8 - 8.824
Im a light weight @ 135 and my times at the track arent bad. 2sec 60ft and a 13.4 @ 104. I spin off the line though with very little mods.
JLT short ram, Jet TB Spacer, BMR Lower Control Arms, Eibach Sportlines, Deleted Front Sway Bar/Passenger Seat/Spare Tire during that run. I could still get my times down with this setup, practice makes perfect.
-Dan
-Dan
Put 4.10,s in and street slicks and you will go 12,8 with that setuo.Launch at 4,500.
Guys I also had the spare tire in back with a tool box that was bout 10 lbs. Have the shaker 1000 system too.
With the mods i Have now.
If I took all this out and the weather was a bit warmer and maybe during the day at a well known track, would my time be under or around 13.1.
Btw what should my car be running with just these mods alone.
I would like to add slicks but cant seem to find a pair of rims ot match a set. im horrible at the sizing. Anyone show me a set of rims and slick that look decent and work great?
Put the rear tires at stock 32 PSI and the fronts at 50 PSI. The 50 PSI makes the wheels have less rolling resistance. I back up to in front of the water box and rev to 5000 and spin the tires till I get to the starting line. Then I rev the RPMs to 2800 - 3000 and somewhat dump the clutch on 3rd yellow.
Lately I've been running the same times as you with about the same mods (well no headers here) in the same temp conditions. I make sure I leave the car shut off for about 45 mins between runs with icebags on the intake. Believe it or not that makes a huge difference, it runs way better cold. Heat soak is a big problem.
IF you're launching at only 2000 RPM with low PSI in the tires, I bet your engine is bogging down on the launch, no?
You can fit Mickey Thompson 3743R P275/40R17 ET street tires on the stock wheels, they run about $178 each plus shipping. I'll be putting these on in the spring.
-Dan
-Dan
I'm consistantly running 13.8xx with my 05, best time was 13.814, I just want to break into 13.7 a bit so I get something a tad quicker. I'm a fairly stock auto trans, just k&n and tune. I am a bigger guy at about 240lbs as well as having the shaker subs in the back. I dont take them out or change tire pressure at all, just avoid the water and rev to about 2000 to launch. I have seen 2 other 05's at the track and both were running best times of 14.2 and 14.5, so at least I'm doing better than them.
I always do a burnout. The Nittos work much better when they are hot and sticky. I also don't think lowering the pressure in a street radial tire does much good. But, to each his own.
Sorry this is off subject...but how do you like your shorty headers? Are they the ram-horn design or the earlier design? Make car sound different? I'd get long tube but dont want to void warranty - as it seems my warranties always come in handy
-Dan
-Dan
Im begining my prep work for my return to the track on the 21st. My LCA relocation brackets are being welded in this Wednesday and Im still trying to get a hold of my friend to see if we can get the 410 gears installed in my driveway.
I will weigh the entire shaker 1000 assembly soon too and will probably pull it for this next trip for further reduction.
I have a CPR fuel rail to install soon too, after it arrives that is. Its really going to clean up the engine bay but I have to rethink my fuel solenoid's feed line.
There is no doubt in my mind that I will hit a high 12second 1/4 this next time out. Its my birthday party after all. :P
-Dan
-Dan
-Dan
-Dan
dohc97
17
Aug 14, 2015 07:12 PM
lol. Weigh 180 5'8. Gym addict. could it be that it was to cold to grip? my 60ft times show no grip right?
