05-08 Hurst Shifter Install
Old Sep 24, 2007 | 10:51 PM
StangPower05's Avatar
Hey guys, im going to be installing the HURST COMP. PLUS shifter soon and would like to know if it was a MUST to reuse the stock busings over the ones that HURST supplies with the shifter. Do the stock ones make a difference or something?? Please, any advice would help. Thanks.
Old Sep 24, 2007 | 11:33 PM
R.A.F.A.L.E.'s Avatar
First, to answer your question straight: NO. It is not mandatory to swap back the Hurst provided urethane bushings for the stock rubber ones.
However, I highly recommend to do the swap. When I installed mine, I found the swap so straightforward that I did not hesitate a second. Just feel both bushing types it's obvious to tell the difference. The urethane feel much tougher and less likely to absorb transmission vibrations and rattles. I have installed the stock rubber bushings on the Hurst since day one and the whole setup is as smooth and comfortable as stock.... only so much more fun & tight to shift Good luck with the install
Old Sep 25, 2007 | 07:08 AM
302svt's Avatar
Great looking shifter but I would stick with the supplied bushing but you could try it both ways and see what you like better.
Old Sep 25, 2007 | 08:52 AM
WaltM's Avatar
I used the urethane bushings w/the shifter. Feels good and solid. No complaints.
Old Sep 25, 2007 | 12:33 PM
mlgstang's Avatar
I also used the supplied bushings, no complaints here...
Old Sep 25, 2007 | 01:39 PM
STANG_IT's Avatar
I reused the stock bushings with no problems.
Old Sep 26, 2007 | 06:34 PM
HURST is installed, any i absolutly LOVE IT!!! Looks and performs great. I went ahead and installed the stock bushings onto the HURST and it feels great. Thanks to everyone for their help!!
Jul 8, 2016 08:53 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
robjh22
Sep 8, 2015 12:31 PM
SMOKE46
Sep 6, 2015 09:40 PM
