Mustang Motorsports All forms of racing and motorsports activity allowed!
Stock hood fluttering at high-speed
Old Apr 17, 2016 | 10:41 AM
redonblackpony's Avatar
I run a track in Southern California that is high speed. Some of the fast cars can hit 150mph. I usually top out about 135mph. This high-speed causes my stock aluminum hood to flutter more than I feel it should.
Has anyone else experienced this and is there a cure other then a replacement hood?
My car is a 2012 and does not have hood vents. I wonder if aftermarket hood vents would help with this? Those of you who have a 13 on with the hood vents, has this occurred at high-speed's with you?
Old Apr 17, 2016 | 03:23 PM
karman's Avatar
Try adjusting the rubber hood supports
Move the rubber bumpers in the front up a little.
This sometimes helps enough.
Old Apr 17, 2016 | 03:34 PM
Are you suggesting that I raise the bumpers taller so the hood fits tighter?
I'll have to check that out.
Do you have first-hand experience with this?
Old Apr 17, 2016 | 03:46 PM
LEXiiON's Avatar
Mine fluttered like crazy when i put it on. I raised the bumpers and gone.
LEXiiON
Old Apr 17, 2016 | 03:52 PM
Good to know. Thanks
Old Apr 17, 2016 | 05:25 PM
dmichaels's Avatar
Couple bits of input on this.
First, 2011-2012's are kinda famous for this. The 2013/2014's don't have this issue largely due to the vents
I got this at Watkims Glen last year and it turned out that the underbody tray came loose in the aft area and was flapping at high speed. That was creating pressure pulses in the engine compartment large enough to flutter the hood. As soon as I reattached the underbody tray, the flutter stopped. So check that. Also consider adding ventilation to the underbody tray as pressure can be released thru that too
Or buy a new racing hood
Old Apr 17, 2016 | 06:00 PM
Getportfolio's Avatar
Mine did the same at speeds above 90. I also have a hood scoop for extra drag...
As stated. Adjust those rubber bumpers and can cut the vibration down substantially.
Old Apr 17, 2016 | 06:06 PM
The underbody tray is fully intact but will be completely covered by next weekend. Installing an APR carbon fiber splitter to replace my boss splitter. Maybe this will help?
While at the track I noticed a lot of guys use the same cut in hood vents made by a local company. Far cheaper than ordering a tiger racing carbon fiber hood for $1600. That hood is bad a$$ though!
Old May 7, 2016 | 01:35 PM
Termi2003's Avatar
Even on the 13/14 the lower Undertray can cause problems......I went off track and ripped mine....I tie wrapped it back up but after that the hood fluttered something awful. Definatley a good place to start.
scottmoyer
May 12, 2016 10:54 PM
redonblackpony
Apr 19, 2016 10:11 AM
TMS Editor
Apr 14, 2016 11:52 AM
Evil_Capri
Which is Better
Apr 14, 2016 07:18 AM
ManuelCarrillo3
Apr 11, 2016 02:32 PM
