Race shop by St.Louis
Just visited ET tuning today out in Union, MO got my car track prepped for street/track drivability and completed NASA HPDE inspection.
Met Jon Rhodes Jr. the owner/race car driver and lead technician Casey. Jon and I discussed what options I had available, what I was looking for, prioritized them, and Casey made the necessary adjustments accordingly.
ET tuning was working on a number of cars (Porsches, Mustangs, Classics, Subaru, BMW, etc) at the shop when I visited. Class act over at ET tuning, recommend them for all your trackday needs.
ET tuning
www.ettuning.com
6 Williams Drive
Union, MO
636-583-9191
Go check them out!
ET tuning
www.ettuning.com
6 Williams Drive
Union, MO
636-583-9191
Go check them out!
thx 5.MONSTER :-) For now toe/camber adjustments (w/ driver) based on our discussion (track vs street) at the shop. Also doing overall inspection/review. Love being around actual race shop :-) I think I learned more from just watching Casey work on my car and talking suspension/car behavior with Jon. Jon also test drives all the cars after job is completed and he gave a brief about what he noticed after (detail down to the effect of the curvature of the road (rain runoff)) Great shop! can't say enough about ET tuning.
yes for now, I hate to mess with that sort of thing because I honestly wouldn't know what I'm doing. They were surprised by have much camber I had before adjustment and they said it's probably because my car is lower (induce camber)
That's a lot of negative camber for every Day Street driving. I'm running -1.7°. With toe set to nearly 0 and I still get inner tire wear.
Camber bolts or always a hassle, maybe want to look into getting some camber plates in the future. Pretty easy to adjust your own camber.
What kind of springs are you running? Is your wheel height shorter than stock? If so, that's more negative camber.
That's a lot of negative camber for every Day Street driving. I'm running -1.7°. With toe set to nearly 0 and I still get inner tire wear. Camber bolts or always a hassle, maybe want to look into getting some camber plates in the future. Pretty easy to adjust your own camber. What kind of springs are you running? Is your wheel height shorter than stock? If so, that's more negative camber.
I think a big part of my tire wear also is I don't really drive it everyday
Gotcha. I'm going to have my alignment\bump steer\camber checked soon. I've been running shorter diameter than stock wheels and I believe I have more like -2° camber.
Like you too, I don't do much Street driving and the track is really hard on my front tires, especially the passenger one.
Sounds good. That should yield good results!
I have Steeda upper strut mounts waiting for install. They give you +/-1 deg of camber. On top of the Steeda Sports I think I can get -2.5 deg of camber for track days.
I worry about having too much mid corner over steer with this much negative camber and square tire setup, but we'll see.
I'll have my car aligned when everything is on, and I'll ask them to set up -1deg with 0 toe for DD. I'll mark the location of -1deg, and go full negative for track days.
