Mustang Motorsports All forms of racing and motorsports activity allowed!
Brake and transmission fluid change
Old Nov 15, 2016 | 04:41 AM
dmichaels's Avatar
Originally Posted by SGwick
This comes in 1L container, how many do we need for brake fluid change?
I believe I just used 1 last time. I buy 2 for a season tgough
Old Nov 18, 2016 | 07:56 PM
5.M0NSTER's Avatar
That's equivalent to 2 500ml bottles. I think 1 should do the trick, but I'd buy 2 just in case. That way you have extra
EDIT: I'm a little late to the party!
Old Nov 19, 2016 | 05:57 AM
dmichaels's Avatar
Have you jumped on the SRF bandwagon? It's a good one to be on!
Old Nov 19, 2016 | 06:04 AM
Bert's Avatar
Do I understand correctly that the advantage of the SRF is that it does not absorb moisture; which means you don't have to worry about storing opened containers?
Old Nov 19, 2016 | 12:18 PM
SGwick's Avatar
SRF still absorbs moisture but its higher "wet" boiling point is what makes it shine (meaning its boiling point after "standardized moisture" absorption. Storing opened brake fluid in containers is still not advised
Old Nov 19, 2016 | 12:33 PM
dmichaels's Avatar
The wet boiling point is about 100F higher than anything else out there. So as it absorbs moisture, it still maintains a very high temp boiling point and requires basically no bleeding through a season.
Old Nov 20, 2016 | 06:31 AM
Bert's Avatar
I was OCD'ing about the open container -- since it comes in relatively large Liter bottles, it's likely we'll have an opened (and reclosed) container around for a long time, and "they" always recommend against that . . . . I guess we're saying that is not a problem because even "wet" it still has very high boiling point.
Old Nov 20, 2016 | 07:36 AM
dmichaels's Avatar
I don't have any data, but my open container from previous season gets fed into the system as spare fluid as needed. So basically I'm with you in that i do not worry about the leftover fluid since even "wet" it has high temp capability
Old Nov 21, 2016 | 06:41 PM
5.M0NSTER's Avatar
Not yet but I will. Just like with the GT500 rear brake upgrade. Next time I do a bleed will be with Castrol. As a side note, I've been using Castrol Edge 5W-50 motor oil, and I'm pretty impressed with it after 2 drain intervals.
RMS70
Feb 24, 2016 10:27 AM
2013kAB
Jan 31, 2016 08:43 PM
Chad@Amp'D
Jan 27, 2016 07:20 AM
puma1552
Jan 20, 2016 02:12 PM
Dlouie
Ecoboost
Jan 12, 2016 11:02 PM
