ZAINO - HOW TO
#61
I skipped the scratch & swirl remover when I ordered thinking it would be ok. Is this true ? I figured, new car, claybar, polish should do it and there aren't any scratches am I mistaken ?
Do you use the Z2 on the bumpers ?
#62
You do the ENTIRE car including bumpers Zaino says wax anything that does not absorb the polish like a vinyl top (haha...but you wouldn't do that anyway) I waxed my lights as well.
#64
Originally posted by hunter@June 8, 2005, 8:12 PM
Thanks. I am planning to do it this weekend. Glass too ? (sorry for being a nuge (sp?))
#66
#67
Actually, waxing windows is sometimes very effective. It sheets water away like RainX and makes it easier to clean in the future. I have never tried it with Zaino so I don't know how it would work. Just make sure not to use Z-5 on it.
BTW, when you are claying your car, clay the windows too! It makes them look a bunch better.
#68
waxing the windows with a teflon coated wax works wonders, if you let it sit overnight in the garage....what will happen is not only easier to clean later but it also sheets the water off when it rains and even prevents the windows from fogging easily
as for cleaning them Ive found the best thing that works is slighty soapy water to clean them and then plain water to make sure no soap remains, just dip a rag into the water and ring it out so as not to get water all over the car (inside and out) and then to dry use a chamois and you wont have any streaks (use a seperate chamois than the one you use to dry car if you use one for that) if you maintain you car this should be sufficient to clean the windows since you shouldnt have any wierd damage done to them like leaving bird crap on them forever and it starts to etch the window...if this has happened then you need to use something stronger than water to bring them back to life....but this method for the most part is a good safe way to clean your windows especially for tinted windows for a great result. There are great window cleaners out there that work fine if you do go that route just remember as mentioned before stay away from anything alcohol based or anything with a high PH like some household cleaners.
#71
Originally posted by JessicaRabbitt@June 8, 2005, 10:57 PM
One of these days Rick, I am going to have to pay you to come out and give my car the full treatment.
hmmm maybe if we end up doing something up in that area and I plan ahead enough I can do it then....
did you by any chance check out that link on the "Hey RRobello" link I posted that goes to the picture of Richard in a speedo you need to check that out....
and your signature is right bad all the time.
#75
Originally posted by GhostTX@June 9, 2005, 4:38 PM
Any issues with waxing the headlights? Especially the plastic headlight covers on the primary headlights?
My bottle says don't use on plastic, vinyl or rubber.
#76
#77
My dealer is doing a Zaino 'Daimond Kote Wax/Polish with undercoating etc' that was included with the purchase of my car.
I wonder, is it useless to put Zaino together with this, or is it just 1 or the other?
Since the Diamond Kote is paid for, I prefer to get that. But Zaino looks great. Should I do both?
#78
the car looks great but...that's WAY too much work....i would recommend mother's three step: cleaner,glaze and the wax....after using the first two cleaning steps, a bottle of their polish will NOT stay on the car!!! it will slide right off and the stuff is so easy to apply...no time at all to do the 3 steps...in fact, on a new car like yours, the cleaner (1st step) will not be necessary...the glaze is an ultra fine polish that will make the paint POP!! finsih off with the carnauba and you're done...no mix no muss...jackg 90seville 97k
