Will sun cause dash to fade?
Just wondering if it's worth using a windshield sunshade in the winter to protect the upper dash. Down here in NC, it may be cold in the winter, but it's still sunny!
I have a black Dash Mat on my dash. Looks good and protects the dash from the sun. I still use a windshield sunshade to keep the heat out when the top is up. I think someone (not Dash Mat) makes rear deck covers, but don't quote me on that!
RASH - Do NOT under any circumstance bring the 'stang out when the roads get icey or snowy. The Yahoos down here ( from all over the country, but mostly up north ) think they can drive like they do back home. The problem is that " Back home" they treat the roads more aggressively and although they get way more ice and snow, they deal with it WAY better. An inch of snow here is worse than a foot up North.
Point is, that same overreaction applies when the locals drive in the white stuff. They slam on their brakes instead of pumping them and end up in ditches or rear ending someone. They overreact to a slight fishtail, overcorrect, and boom. They don't have the experience to drive in even a small amount of snow.
That's not to say that there aren't overly confident northerners causing problems - there certainly are. In particular, we get much more ice down here, and they think you can drive in that the same way you drive in snow. Wrong. Boom.
So you're right - best to stay off the roads with the stang down here when it snows!
I am a transplant also ( born in Mass ). In my opinion it is more the poor road conditions and maintenance that causes the problems. The transplants assume the roads are treated as well as up north. I forgot to add the part about the locals who never learned to drive in the snow. When I was stationed in Millington TN, I saw a guy trying to pull into a spot in an icey parking lot. His tires were spinning at about 30 and he was moving at about 2, he was lucky and never got traction.
Also, the bread milk and eggs thing kills me. Is there some unwritten rule that everyone is supposed to have french toast the day of a snowstorm. I don't remember that from growing up.
I'm another Yankee living in NC. I moved here from Washington DC about 2 years ago. A agree with everyone about putting up the windshield screen. Also using a good protectant (Armorall) will help prevent fade.
As far as how they deal with the winters in NC, it's the only place I've seen them close the schools because it RAINED!
spf-40 Just kidding.... check this place http://www.autopia-carcare.com/
That site has a lot of great info and some of their products arnt half bad either.
The dash is solid plastic...why would you put upholstery conditioner on it? Makes no sense. Just use common sense. Park in the shade of a building if you can, and put your sunshade up - it'll protect more than your dash.
Direct from Wax Station website:
Our Protectant is a penetrating UV blocker, effective on rubber, vinyl, plastic and fiberglass. Constructed to recondition and maintain the original condition and appearance of dashboards, vinyl, bumpers, trim, tires and more. Preserves Protectant isn't an oily surface-coating film. It's an ozone and smog resisting, UV shielding penetrant a preservation agent that works on just about any uncoated plastic or rubber.
This product was formerly named Preserves Protectant but it is still the same product you have known and trusted to protect your trim parts and, as always, will never promote cracking of your dashboard.
This is why I use it on my plastic parts including the dashboard.
Here is an interesting page at the USM Polymer Science Learning Center about why dashboards crack. The last paragraph is about ArmorAll...
Old soft vinyl dashes dry out and crack because the plasticizers (chemicals that make the plastic soft) dissapate in UV light exposure. However, the hard plastic dashboard in the S197 doesn't have plasticizers to make it soft, so it should be much more durable.
