"Sizzle"sound when washing car
I was washing my car yesterday when I heard a "Sizzle" sound coming from the engine compartment. Sounded as if the water was going in the engine and hitting something hot and the water was evaperating . It was a cold day and I even saw steam coming from the engine compartment. Has anyone heard this too??. Is this something I should worry about???
it probably wasn't going inside the engine per se- it probably just hit something hot.... unless your car doesn't run- i wouldn't worry about it- but at the same time... dont go dumping cold water on a hot engine too....
It was probably water on the exhaust.... but like Sara said, be careful with hitting your hot engine with cold water. .... especially since these engines are all aluminum. Iron won't be effected quite as much, but it doesn't take much to warp aluminum..... plus, how would you like it if someone bathed you in cold water... just drive the car inside and draw a nice warm bath for it. .... be sure to wash behind it's ears.
I took my to a wash station yesterday. I power washed the whole car to get some salt off it. When I sprayed the hood off, I did see steam comng out after I stopped spraying that area. I am not sure if it goes down between the hood and side panel, then it hits something hot.
There is a slight gap between the hood and the cowel panel. Water being sprayed onto the front windshield gets deflected and makes its way under there. The Sizzle you hear is from the water hitting the headers. Next time you finish washing your car, pop the hood and you will see where the water is getting onto the engine.
Originally posted by MaverickMLFD371@December 17, 2004, 2:13 PM
could be ur brakes......
Originally posted by clintoris+December 17, 2004, 4:24 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (clintoris @ December 17, 2004, 4:24 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-MaverickMLFD371@December 17, 2004, 2:13 PM
[/b][/quote]depends on your breaking, you can be a hard braker or a soft braker, it all depends
Mackitude
Aug 13, 2015 01:05 PM
lakersfreak
Aug 12, 2015 01:52 PM
