Scratches on Center Console
I have a few light scratches on the center console of my '05. In my '98, the center console was much more textured, so even if there was a scratch, it didn't show. Does anyone have any suggestions, short of replacing the console, that I could reduce the obviousness of the scratches as much as possible. I was hoping some of you car guys would have some tricks up your sleeves.
I was thinking about rubbing it real lightly with toothpaste, since it is the most mild abrasive I can think of. I will try a concealed spot first to make sure it won't harm it. But if anyone has a better idea, please let me know. I am shooting in the dark with the toothpaste thing.
I'm in the same spot. I've already got two small knicks in the plastic, right by the cup holders. It bothers me because I'm pretty sure I didn't cause them. I think a tech scratched them with his keys!
The only quick fix I could suggest is armor-alling the console. The shiny surface will make it harder to notice scratches. Only problem is, I prefer the matte finish of the console and I don't like the smell or feel of armor all.
The more expensive alternative is getting the silver applique finish, available on the aftermarket.
Could cover it up with a facing piece from woodview or another carrier. I am thinking of getting the satin nickel finish consol facing to help prevent scratches. When I picked my car up it had three scratches on the consol and they had to replace it.
Hey Tim, if you like the look of the silver applique, I would suggest getting it for the center stack, as well as the console.
Wild Stray's dash and console look pretty cool. Check out the pic he posted in the mods section. I know it won't help the scratches already on your console, but it might hold up better to wear and tear.
Yea Tim dont use toothpast or anything that says it removes scratches as it is lightly buffing them. it will remove the matte, which is probably chemically etched on the surface, and leave you with a gloss finish. What about that clear bra 3M stuff I have heard you guys mention? I have never seen it and have no idea if it is sprayed on or a roll but for those of you that know do you think it is something that could be applied to keep out the scratches?
