Not another scratch! Need some advice!
I got out and washes/detailed my car today since it was finally nice out here in PA, and what do i find? A nice long scratch on my drivers side door...Its a light one but still a scratch none the less. Any advice on how to get rid of it? I dont want to risk any more damage to my paint, and Ill take it to a professional if I have to, but I just wanted to try and see what I can do first.
usally, as long as its not too deep, a scratch should come off with rubbing compound and elbow grease. If it damaged the paint, Ide bring it to a professional.
p.s. Are you still looking for a mineral grey GT rear bumper. I had mine replaced after i was involved in a minor rear ending and i still have the original. Its still in good shape, p.m. me if you want some pictures.
I cant feel the scratch with my nail, but i can definitily see it. Thanks for the tip on the Meguiars stuff, got any good places online to get it?
And about the GT bumper, Im still looking for one, how badly is yours damaged?
Edit: I found this online, http://meguiars.com/?pro-paint-clean...ne-Cut-Cleaner ,Is this the same stuff you are talking about?
Meguiars Mirror Glaze 3
The 1st bottle. This is the stuff to use.
TRUST ME:
Meguiars ScratchX - BEST STUFF for a scratch. Use just a little bit on a small section of the scratch at a time.
Then go here to reduce your chances of getting more:
http://www.parkingbydesign.com/
TMS West Coast Correspondent
if you have a DA buffer than use Meguiars M#80 or M83(slighlty more aggressive), if not then by hand Scratch X, all will fix the problem if it can be fixed and if they cant then you need to have it touched up or spot painted but these 3 products wont make the situation worse at all. Then follow with Meguiars Show Car Glaze then High Tech Yellow.
IMO, you cant really make it any worse than it is. Any of the products mentioned will get rid of the scratch and any small scratches left can be buffed out.
I own a black Stang that shows every little imperfection. I've had good experiences using Meguiars Scratch X. It may take several applications, but it should work- and it is clearcoat safe...
All the abrasive compounds do is dull up the clear coat, giving you a rough surface down to the depth of the scratch . If you have a scratch on your car, that means its at LEAST as deep as the clear coat, if not, then it will rub right off with no effort. I spent this weekend removing some pretty noticable surface scratches. In the end, the best way for me was turtle wax rubbing compound heavy duty cleaner, a small amount of water, and meguars show car glaze deep shine polish. I am left with absolutely no imperfections where the scratches were. Again, this is only good for surface scratches where all the paint is still intact, just under the scratch. If any paint is gone, Ide bring it to a professinal to touch it up.
You just put a little bit on a microfiber, and rub a very small area.
The nice thing about it is that it has what they call "diminishing abrasives" which means once you rub it a few times back and forth, it becomes less and less abrasive, reducing the chance that you'll do damage. That's why it may take a couple of applications.
(Can you tell I've been to a couple of classes at Meguiars? )
Good luck!
There is obviously a limit to what ScratchX can do. But if you've got a small scratch in the clear coat, it's the product to try first. Unlike very abrasive compounds, I've never seen it dull the finish.
Mr. Sparkle
9/11/15 02:57 PM
