Meguiar's NXT Liquid vs. Paste Wax?
Old May 18, 2006 | 07:30 AM
T Town Bobby D's Avatar
Really loooks good
Old May 18, 2006 | 04:09 PM
SOLDSHORT's Avatar
nxt liquid wax
Old May 18, 2006 | 06:39 PM
adrenalin's Avatar
Just an FYI. The main reason they make 2 versions, paste and liquid is generally you apply the paste by hand and the liquid is required when using a buffer. Both will have the same results, however, the paste will last longer (not on the car) because you will waste more when using the liquid type.
Old May 29, 2006 | 11:58 AM
Agent45's Avatar
The best advice I can give when using NXT is using several soft towels to remove the wax. Use one to rub off the initial wax application, then go back and use a clean towel to polish the car. I have found that even with the slightest amount of wax residue on a towel, you wont get a sparkling shine. Then, to top it all off, mist the car with the NXT speed detailer and wipe immediately. Final step- put car cover on and never drive it!!!
Old May 30, 2006 | 02:00 PM
SOLDSHORT's Avatar
the more you do after you apply and remove the nxt, the less it will protect your car and last. Do the initial wipe down slowly with a microfiber then don't touch it till the next day if possible. In a perfect world, actual NXT wax cure time is 12 hours.
NC14GT
Sep 10, 2017 04:47 PM
robjh22
Dec 14, 2015 08:41 AM
NC14GT
Sep 27, 2015 05:35 PM
samjluck
Sep 17, 2015 10:24 PM
TripleBlack14
Sep 17, 2015 07:48 AM
