I Love Clay Bars
Just finished giving the ol' GT a quick wax for an upcoming Mardi Gras parade. Clay barred it before and am STILL amazed ad how smooth it comes out and how easy the wax comes off.
Bottom line. If you haven't tried it, do so now. You'll love it.
I know. I'm preaching to the converted. . . .
Originally posted by OMENLOCO@February 10, 2005, 10:25 AM
where does one get a clay bar?
so at what point do you use the clay bar? Do you wash it, dry it then do the clay bar and then wax it ...or do you do the clay bar 1st and then wash it...or when you use the clay bar do you not have to wax it after?
Depends. If you drop it, it is toast. So don't do that! If you get your car good and clean before you clay bar, it'll last quite awhile. The one I have I have been using for about 1.5 years now. Depends on what is on your paint.
A good tip is to tear off a piece of the clay bar and use it until it is "wasted" then tear off another piece, repeat. I have found this makes it easier to use since I end up with one very thin, wide piece of clay that is easier to handle and moves over uneven surfaces easier.
Also, nothing makes you feel quite as dumb as dropping your clay bar, (eventually you will), and this way only a piece is toast instead of the entire bar when this eventually happens.
I claybar'd the front and hood of my 05 GT and 02 Coup yesterday, followed up with step 2 and 3 of Meguire's Deep Crystal and wow! It rained this morning, but when it clears I will do the roofs and door panels next.
I have been lax in putting in my hood pins, but now that the hood has been done for the spring, I can drill some holes!
