How to remove surface rust on brake rotors
Old Jul 21, 2013 | 08:04 PM
Boss89's Avatar
We have surface rust from winter storage and age on the inner and outer edges of the brake rotors on our 2008 Mustang that I would like to remove without painting. I am not talking about the contact surfaces. We are preparing this car for the upcoming National MCA show in Indianapolis. Any ideas? Has anyone tackled this problem? Will wire brushing make scratches? Will naval jelly dissolve it and remove it? Thanks
Old Jul 24, 2013 | 01:02 PM
Missouri Hoss's Avatar
I tried priming and painting them with Rustoleum and that didn't work. The orange rust still bleeds from the cooling fins between the inner and outer contact surfaces. That rust and brake dust also coats the inside of our wheels. I also look forward to suggestions how to cure the rust problem on OEM rotors. As much as I hate to replace new rotors, I'll probably switch to a brand that is corrosion resistent or stainless.
Old Jul 24, 2013 | 01:32 PM
AlsCobra's Avatar
A Man Just Needs Some....
Get them resurfaced. Clean up the sides with a small buffing wheel. Tape off the contact area and prime the rest. About the only thing you can do without replacing the rotors.
Old Jul 24, 2013 | 01:52 PM
scotch brite pads
Old Jul 29, 2013 | 10:03 PM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
Jack car, use stands, remove wheels, then using goggles, gloves, cup brush attached to a 4 or 4-1/2" angle grinder .... did I mention goggles and gloves? ..... rotate rotor as you work on most comfortable surfaces and don't allow the spinning brush to wedge the machine in tight .... use goggles and a firm hand hold.
Then clean with a paint prep soaked wrag and prime and paint ..... or just paint if looking for temp.
Old Jul 30, 2013 | 11:56 AM
but use goggles ...ok
Old Jul 30, 2013 | 12:41 PM
Why he no say dust mask??
Did I mention dust mask??
Old Jul 30, 2013 | 07:28 PM
DaGonz's Avatar
+100 on the dust mask... not only is there rust but brake dust, you don't want to breathe that crap in!
Old Aug 3, 2013 | 02:19 PM
Boss89's Avatar
I ended up using the wire cup method on a drill. I don't want to paint them because there may be a day when I want to enter concours competition. I meant to try naval jelly but wasn't patient enough and went straight to the wire cup. Plus one on the mask and safety glasses!
bones302
Oct 7, 2015 04:42 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
