Fall Roll Back Part 3: Save up to 40% on Select Brands!
Fall Roll Back Sales are BACK and BETTER THAN EVER! Save up to 40% on select brands, including Marine 31, Bouncer's Waxes, Tuf Shine, Permanon, Sonax, Daytona Brushes, and Dodo Juice! Sale ends Friday, October 11th.
Be sure to pay special attention to Marine 31 and Daytona Brushes, both of which are marked down lower than they ever have been. Trust us when we say that you'll never see prices these low again!
Click HERE to start shopping!
Not sure where to start shopping? Here are a couple of our top picks:
Up Close & Personal: Marine 31 Stainless Steel Liquid Polish
Originally Posted by Nick@Autogeek
Marine 31 Stainless Steel Liquid Polish is the perfect solution to dull, oxidized, tarnished metal surfaces on your boat. This medium-cut polish is designed to restore the shine and luster to uncoated aluminum, stainless steel and chrome with very little effort. Marine 31 Stainless Steel Liquid Polish creates a highly reflective finish that can be seen from a distance.
Metal fixtures on your boat are susceptible to oxidation and surface rust, especially if your boat is docked in salt water. Marine 31 Stainless Steel Liquid Polish stops oxidation and surface rust in its tracks! This easy-to-use, thick metal polish uncovers the mirror-finish that was present on your boat’s stainless steel, aluminum and chrome surfaces when it was new.
Tuf Shine Tire Clearcoat: Permanent Tire Protection Made Simple
Tuf Shine Appearance Products has been manufacturing cutting-edge surface care products for nearly a decade. Tuf shine Appearance Products has been gaining traction as an innovator in the industry with breakthrough products like Tire Clearcoat and Black Restore – two products that make long-term tire and trim care effortless. Tuf Shine Appearance Care Products are environmentally safe and effortless in their application.
If there is ever going to be one brand that is recognized world-wide for producing the most complete line of innovative, state-of-the-art tire care products, Tuf Shine is that brand. Tuf Shine Tire Cleaner and Tuf Shine Tire Clearcoat turned the car care world upside down by providing an unmatched level of cleaning (Tire Cleaner) and protection (Tire Clearcoat) abilities. Tuf Shine took something as simple as applying a tire dressing – a task that is usually performed on a regular basis – and made it permanent with Tire Clearcoat.
Up Close & Personal: Daytona Speed Master PRO Wheel Brush!
The Daytona Speed Master PRO Wheel Brush is the answer to hundreds of emails and dozens of phone calls from loyal Autogeek customers over the years asking for a wheel brush that could be used, abused, washed and reused thousands of times. The wait is over because the Daytona Speed Master PRO Wheel Brush has arrived.
The Daytona Speed Master PRO Wheel Brush was designed for the detailer that requires a brush built to withstand the rigorous use of every day wheel cleaning. From the half-inch thick, heavy-duty non-slip polypropylene handle to the chemically resistant Nylex bristles, the Daytona Speed Master PRO Wheel Brush was designed to outperform and outlast any other wheel brush.
How to apply Permanon Platinum Finish Protection
Originally Posted by Bryan@Autogeek
I have been waiting to try Permanon Platinum for a while but was not sure how to go about doing it. Since there was a lack of information about applying Permanon Platinum I decided I would take advantage of it. When using this product it needs to be diluted so it a cost effective product. If it is used properly you should be able to do about two cars with a 32oz bottle and 40 cars all together. This product is going to protect your car and make washing it easier since it will not let the dirt and other contaminates bond to the surface. Permanon Platinum will also provide UV protection.
Review: Dodo Juice Ferrous Dueller Iron Remover
Hey guys I had a chance to try out the new Dodo Juice Ferrous Dueller Iron Remover. Dodo Juice Ferrous Dueller Iron Remover can be used on wheels, glass, and paint. You can use Dodo Juice Ferrous Dueller Iron Remover to remove rail dust and other contaminants on the surface without to physically remove them. When using this product I went over the whole car with a foam gun filled with Auto Finesse Avalanche Snow Foam (Review coming soon). By going over the car with a shampoo it ensures you do not waste product on dirt that you can wipe off. Once the car was clean I went around and sprayed each panel with Dodo Juice Ferrous Dueller Iron Remover.
roushcollection
7/28/15 02:08 PM
Autogeek.net
7/14/15 09:48 AM
