To Claybar or not to Claybar, that isthe question!
I'm getting my new stang soon, and I'm wondering how many of you out their claybared their car or not. I want to see if it's really necessary on a new car. I'm skeptical about doing it. I'm thinking if the car feels smooth enough, that I should just polish and wax.
I'm reluctant to claybar because I'm at an apartment and there's no convenient place for me to claybar and wash my car.
Done mine twice now..It makes a big difference..Yes there is alot of rail dust and just about any new car..but then on a white car you can really see all the stuff that gets into the paint... I also live in a apartment..But go to a friends house..
No need in my opinion. Just a wash and wax is all it needs. Any bits of dirt or gunk comes out with a little elbow grease when you're washing the car, so it's smooth as a babies bottom.
The fact is that every car shipped by train is covered in rail dust. Some washes off, but a lot embeds in your clearcoat and cannot be removed by washing (even with elbow grease). It may feel smooth to you, but it isn't. Claybar a 4 inch square then feel the difference between it and the surrounding area. You will be shocked at how much smoother the claybar section is. I was and I claybar'ed my Stang on day 1.
Using the claybar is very simle, does not require extra effort to be effective, is not that time-consuming and is safer for your clearcoat.
You can give it the elbow grease and trust that your car is clean or you can claybar and know your car is clean. Which is better for the long-term care of your car's appearance?
I agree with Buck. The car felt pretty smooth and the claying went fast - but with all I have heard about rail dust, I wasn't going to take the chance. Find a nice shade tree someplace.
Or go to an automatic car wash and hog a covered space for a while.
Claybar is the real deal. I was a skeptic, but once I tried it I was amazed at how much smoother the surface of the paint was. Washed it with Zaino's wash then used Zaino's polish. The claybar is well worth it!
Ok, so how should I do it?
Since the dealer already washes and waxes, I'm thinking I have to
1. Rinse then Wash and rinse again
2. Dewax using dawn solution, then rinse
3. Claybar, then rinse
4. Polish
5. Wax
Does that sound right?
4. Polish
5. Wax
I used dawn as my first wash.
I then used Zaino Z-7 as a lubricant for the claybar (claybarring will also have you touch every square inch of your paintjob so you will not be surprised by any scratches later)
Z-7 wash
Dry - difficult place to dry is under the grill, water seems to puddle and keep coming out
Z-5
Z-6
Z-2
Z-6
I have only used Zaino, others might be able to give other ideas
Z-7 wash
Z-5
Z-6
Z-2
Z-6
never heard of this claybar stuff, but it sounds like it is something to do, is it safe to use now-the paint is only 3 months old, also is this a paste form or liquid, can you use it on the plastic bumpers
Where do you buy it from ?
Claybar is just like it sounds....a bar of clay, therefore it is a solid. The way it works is you spray some automotive detailer in an area (usually provided with the bar) and then you rub the bar back in forth in that area. The purpose of the spray is to keep the bar from sticking to the car. Any particles sitting on the paint (rail dust, tree sap, etc) will stick to the clay bar. In the end you have a very smooth surface before you apply the wax. A thing to remember is that since the bar is trapping all of those particles, you need to keep folding the clay to a clean section. Depending on how often I use the clay bar, which is usually only a few times per year on each car, I normally replace the bar every 2 years. I try to buy bars that are white, like Mothers, that way I can see just how much stuff it has removed from the car.
Thank you. Now I know what claybar is.
The Claybar really does make a difference. It takes a little time to do it right, but it's worth the effort.
The Zaino web site has good step-by-step directions. Here's the link:
http://www.zainostore.com/Merchant2/mercha...WC&Store_Code=Z
I wasn't sold on claying before I got my car (this past monday), but wanted to do everything "right". So I did it anyway. During my 'dawn' wash before claying, I found a black scuff all up and down the right rear corner. It really looked like a scratch into the paint, but seemed to be the wrong color, and my fingernail did nothing to remove it. When I got there with the clay, one pass removed half of the marks, another little bit of work later and it was all gone. Brilliant! So, now I'm a believer.
There was actually less crap in the clay than I expected, but my only comparison was a trial run I did on my wife's Saturn. That car has been so neglected that all kinds of stuff came off. I was a little dissappointed as there was a lot of crap on her car that didn't come up easily at all, and I had to go to my fingernail for a bunch of these wierd dots on the hood. Still don't know what they are/were, and there are still more. I really ought to go over that car again, but these days the other is demanding all my attention.
