The 'ask any detailing question' thread
Can I resurrect an old thread? I live in the great Pacific NW where it rains and rains and rains. I must drive my black GT or it would never be driven. The problem is when it rains after a few days there is a buildup of dirt stuck to the car. After washing it has swirls. I use the 2 bucket method and constantly rinse the two mf mitts. I use a blower to get rid of excess water and pat dry with new mf towels. It doesn't stop the scratches. Obviously extremely frustrating. I knew this would be an issue since I have had black cars in the past. Any suggestions to prevent or cut down on the swirls or will I have to spend a day polishing each time I wash it?
If the answer is no, then obviously buff it and get it swirl free. Then proceed below.
If the answer is yes, and you're getting swirls, understand that ANY color paint WILL get swirls no matter how careful you are washing etc. Black just shows it easily. Swirls just happen over time. Anytime you touch your paint with a mitt or cloth or whatever, you are scratching paint. Period. Now, what you can do is REDUCE the amount of swirls/scratches you put back on. Continue to do your proper techniques. Then inevitably, buff your paint 1x or 2x a year...usually a light polish is all you need. One in spring one in fall. That's what I do.
Accept the swirls. Just remember proper detailing techniques and correct paint as necessary.
I have had it about 3 months and only have waxed it so I doubt that removed all the marks. I plan on using a clay bar, polish and wax once the weather clears.
b) your clay bar, polish, and wax, won't remove swirls. The ONLY way to remove swirls is to paint correct using a buffer. Unless your arms/hand can move at 6000 rpms. Only purpose of wax is to enhance the look of perfectly swirl free paint, along with some minor protection from elements.
a) so then the swirls were probably already there to begin with (either dealer induced or prior owner induced
I also have a porter cable dual action polisher and having such tool is the way to go.
I'm not familiar with that brand/equipment. Chances are, if it's something relatively cheap that was obtainable from Autozone or Kmart, it will probably do more damage than good.
Stick with a reputable Dual Action (DA) or Rotary (but more for advanced users) polisher. As folks mentioned, Porter Cable (PC), Griots, Meguiar's, etc... are decent. Visit sites like autogeek.net and buy any brand polisher on their site (or get it elsewhere, just note the brand and type). You'll need a good polisher, at least 2 sets of foam pads with varying cut, and polish and compound, and tons of MF cloths. Make sure you clay your paint before buffing.
Question-I just purchased the Porter Cable DA polisher. It has the polishing pad...now what. Are there pads or mitts that go over it? Or do I purchase different pads for different uses that thread onto the spindle of the polisher. Someone please advise.
http://adamspolishes.com/shop/access...plicators.html
So the pads you showed me a link too, just Velcro to the Porter Cable pad and the colors let me know what compound I am using on what color pad...got it. Now what compounds or polishes should I use. Thanks for your patience on this.
here's what I use:
for paint correction and finishing...
http://adamspolishes.com/shop/kits/4...ish-combo.html
then i apply a sealant
http://adamspolishes.com/shop/exteri...t-sealant.html
also when i'm applying my polishes I use the quick detailer spray to lubricate the pads by just spraying 2 squirts onto the pad before applying the polish to the car.
I also apply the brilliant glaze at the end...
http://adamspolishes.com/shop/exteri...ant-glaze.html
it adds what looks like another layer of glass to the paint. it's super easy to apply. just spread it on by hand and wipe off. no machine needed. IN fact i only use the porter to apply polishes. I apply sealant and glaze by hand with microfiber.
