Center Break light does not work. Tested harness and there is power when break peddle is pushed. Other break lights work correctly. Installed new center light but that did not work either.
Has anyone run across this situation and how did you fix it?
Here are Some 2011 Wiring Diagrams that maybe Helpful. Looks Like the CHMSL is Controlled by Module B per #5 Hope this Helps. Wiring is not my Strong Suit. May or May not Need Replacement or Reprogram. Not Sure if this One is Reprogrammable. Sorry not at Dealership Anymore or I could check Further.
