Will a 3.8 Alt fit a 3.9L V6?
Old Aug 19, 2019 | 07:03 PM
DVA's Avatar
DVA
Hey all!
I’ve got an 04 3.9L V6 with Charging issues. Basically the amount with the amount of aftermarket parts, the 105 AMP alt isn’t putting out enough power to charge the battery, resulting in voltage drop. I’ve tested wires, the battery, parasitic draw - all is in good shape - which leads me to conclude I need an Alt with a high Amp output in order to charge the battery correctly.
ANYWAYs, does any one know if the 3.8 130 AMP Alternators would fit the 3.9L Engine? Are they the exact same size? I know they’re basically the same engine - I just want to make sure to be safe before I make the purchase.
Thanks!
Old Aug 19, 2019 | 09:46 PM
houtex's Avatar
The bracketry/mounting aren't the same. That said, here:
https://www.americanmuscle.com/130am...0304cobra.html
That is for your model year and engine. 130 amp. So they do make them. This is but the first example I alighted upon with a google search of '130 amp 3.9l mustang alternator', there are others out there.
Hope that helps,and welcome to the forums!
Old Aug 19, 2019 | 10:15 PM
DVA's Avatar
DVA
Thanks so much for the info!! Glad I didn’t buy the one I had my eyes on only to find out the fit wouldn’t line up.
Thanks!
junkman27
May 21, 2016 01:02 AM
2000gtsilverstang
Feb 27, 2011 10:42 AM
1973Mach1
Mar 13, 2007 05:45 AM
Mestizo
1994-2004 V-8
Oct 3, 2005 10:00 AM
