Wheel hop!
Old Oct 20, 2013 | 01:16 PM
black-sunshine's Avatar
Wheel hop!
Hey I have a 2010 GT with a 5 speed manual and 3.73 gears and a limited slip differential. It has the track pack option. I know wheel hop is common with these type of rear suspensions. Is their anything out there that would help eliminate or reduce the wheel hop! I can get a solid burn out going then it ends up in wheel hop. Any help please! Thanks!
Old Oct 21, 2013 | 05:43 AM
rriddle3's Avatar
First step would be replace the factory rear lower control arms with good aftermarket ones (BMR, Whiteline, Steeda, etc).
Old Oct 21, 2013 | 06:12 PM
tj@steeda's Avatar
Here is a video that will help with your wheel hop
You can check out the install here on another thread ... very thorough.
Let me know if I can help you with a set?
https://themustangsource.com/f669/st...461715/index2/
Best Regards,
TJ
Old Oct 21, 2013 | 06:25 PM
MadGT's Avatar
Legacy Tms Member
Steeda LCA for the WIN!!!
Old Oct 22, 2013 | 01:02 AM
Thanks for the info and help. I'm thinking of replacing the upper control arm also and the pan hard bar as well while I'm under the car. Looks like it will be a massive improvement. I will need to wait for tax time to upgrade. Any more tips or info is greatly appreciated! Thanks!
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
