Saleen Rim Centre Caps
Good morning,
I am having a difficult time locating replacement centre caps for my 95 GT Saleen rims, 60mm outside diameter...any leads would be greatly appreciated!!
Thanks you!
Thanks you!
The Analog Admin!
Received 3,026 Likes
Do You Have Any At All?
A Picture and Any Numbers on Inside Would Be Ever Helpful To Help Search!
Even a Picture of The Wheel Itself and or Any Number off of Those as Well!
KC
KC
The Analog Admin!
The Analog Admin!
If You Are Not Dead Set on an Absolute Genuine Set I think I Would Get Something Like These Stickers and Some New Matching Center Caps.
https://www.ebay.com/itm/23506479537...HTVJ2N2DCANM9K
The Analog Admin!
Been Down This Road.
You Need To Find Listings That Have Good Measurements Shown Like This!
In Fact I Have Used This Brand And They Are Pretty Good But {Some Sizes} Are a Bit Domed.
I Would Get Caps First and Then Get Sticker To Fit. They Should Fit Inside The Area Before Outer Edge Flares Up {If Size Has Flare} For Best Adhesion.
Regardless Of What You Get A Listing With More Precise Measurements Will Net Best Results
Another Example of Proper Measurements
By Eyeball and a 60MM Outer Top Diameter This Looks Promising?
Also A Trip With a Wheel To a Local Tire Shop That Sells a Lot of Aftermarket Wheels May Have a Selection To Try Before You Buy as Well is an Option.
I Found This Interesting Info!
https://www.saleenclubofamerica.com/SCOATech/94-98.htm
KC
KC
