Saleen Rim Centre Caps
Good morning,
I am having a difficult time locating replacement centre caps for my 95 GT Saleen rims, 60mm outside diameter...any leads would be greatly appreciated!!
Thanks you!
Thanks you!
Do You Have Any At All?
A Picture and Any Numbers on Inside Would Be Ever Helpful To Help Search!
Even a Picture of The Wheel Itself and or Any Number off of Those as Well!
KC
KC
If You Are Not Dead Set on an Absolute Genuine Set I think I Would Get Something Like These Stickers and Some New Matching Center Caps.
https://www.ebay.com/itm/23506479537...HTVJ2N2DCANM9K
Been Down This Road.
You Need To Find Listings That Have Good Measurements Shown Like This!
In Fact I Have Used This Brand And They Are Pretty Good But {Some Sizes} Are a Bit Domed.
I Would Get Caps First and Then Get Sticker To Fit. They Should Fit Inside The Area Before Outer Edge Flares Up {If Size Has Flare} For Best Adhesion.
Regardless Of What You Get A Listing With More Precise Measurements Will Net Best Results
Another Example of Proper Measurements
By Eyeball and a 60MM Outer Top Diameter This Looks Promising?
Also A Trip With a Wheel To a Local Tire Shop That Sells a Lot of Aftermarket Wheels May Have a Selection To Try Before You Buy as Well is an Option.
I Found This Interesting Info!
https://www.saleenclubofamerica.com/SCOATech/94-98.htm
KC
KC
