Question about spark plugs
Tms Mustang Member ------ The Customizer!
deleted
found my answer
Aw, MAN. I SO wanted to just point to my post of this thing and that thing and tell you all about stuff and then sidetrack then retrack and all, but nnnoooOOOoooo, you had to figure it out.
FINE. Be that way.
*wanders off grumblin'*
FINE. Be that way.
He should've found his answer, knowing how many threads about spark plugs have been submitted time and time again on this site over the years
spark plug torque values when threads are wet, not dry
Swapping plugs in '08 4.6, following TSB. When threads are wet from penetrant, should I lower the suggested torque values from 25-ish ft/lbs to a lower value?
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,866 Likes
https://themustangsource.com/forums/...6/#post6643485
See Last Section on Installation if Plugs are Already Out!
KC
KC
First off! Ford recommends only applying a thin coating of high-temp/nickel anti-seize to the ground barrel shields, but never onto the threads as doing so will affect the accuracy of the torque values.. Also keep in mind it's the ground electrode shield (barrels) which end up getting stuck inside the heads due from carbon build-up and not the threads themselves... In regards to the torque value specs, Ford recommends 25 ft. lbs. torque...
Meanwhile, thanks for sharing an image of your "08" GT/CS as she's absolutely stunning and also welcome aboard
