PDR how much does it cost?
Old Jun 7, 2014 | 05:49 PM
Did they come to you or did you have to drop your car off somewhere? How much did it cost you per ding?
Old Jun 7, 2014 | 05:55 PM
GrnT's Avatar
I went to my ford dealer. It costed me 75 dollars for 2 dents. I dropped it off and picked it up 2 hours later. Can't tell the dents were even there.
Old Jun 8, 2014 | 06:28 AM
NC14GT's Avatar
A few years ago I accidentally dropped a heavy box of Christmas decorations on the crease by the front hood. It seemed to be in a horrible location and I was &*#!
I called the local dealerships to see who they used. I called him and then drove two hours to his place. He fixed it while I waited (about 30 minutes), and $200 later I was on my way. I can not see the prior dent no matter how hard I try under all types of lighting.
The key is to find the right guy which is why I asked the dealers who they use. In this case, they were spot on.
Old Jun 8, 2014 | 12:16 PM
wanted33's Avatar
Mine was done under my insurance coverage, so I don't remember the cost exactly. Seems like it was around $250. I have probably half dozen hail dents fixed. Like other said, I couldn't tell they were ever there when the tech finished. I would have paid that even if the insurance wouldn't.
Old Jun 8, 2014 | 08:36 PM
Mickstang's Avatar
Glenn, if you can bear to look at the damage for a while, parking the car out in the sunshine might result in Mama Nature popping a couple of those dents out and/or shrinking a few. If you are paying out-of-pocket, this could soften the hit a little. Just a thought.
Old Jun 10, 2014 | 09:12 AM
69Mach1-409's Avatar
I have 6 small dents on my roof of the Raptor from hail acouple weeks ago and was quoted $200 - $300 depending on how much of a pain the headliner is to drop sense I have a sunroof.
Old Jun 10, 2014 | 10:10 AM
Thanks for the replies Gents. Sounds like prices vary a bit.
Old Jun 10, 2014 | 05:34 PM
scottmoyer's Avatar
I do PDR and yes the prices vary based on the size and location of the dent. Every dent is different, so it's hard to have a set price for every dent. Also, today's cars are a mix of aluminum and steel panels. Aluminum is much more difficult to work with so an equal size dent to one on a steel panel, will cost more. Also, I don't drill, so a dent in a tough spot may require more panel removal or glue pulling.
Dry ice and heat don't "remove" dents. The heat causes the panel to swell and moves the metal around a may cause certain dents to "pop" or shrink, but the dent is still there. If anybody ever suggests heating the panel then hitting it with dry ice, run away! That shocks the metal and can cause the paint to separate from the panel.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
GLOCKer
Sep 28, 2015 05:20 PM
