NEED HELP BCM PROBLEM
I have a 2006 mustang V6 4.0 L my BCM got wet and i need to replace it i went to several junkyard and can't find one whit number 5r3t-14b476-be. I found several whit other numbers. my question is can i put any BCM that doesn't match the one in my car or does it have to be the same. I went to ford dealership and they told me it has to be the same is this true or not SOMEONE HELP Thanks
Read over the attached links provided below.. These cover both replacement and ECM reprogramming procedures.. Meanwhile, welcome aboard.
https://www.vehicleservicepros.com/s...her-procedures
https://carcomputerexchange.com/sear...=247&year=2006
https://www.fs1inc.com/ford-pcm-ecm-...el=48&year=139
https://www.solopcms.com/blog/everyt...le-reflashing/
https://moduleexperts.com/engine-con...BoCkVcQAvD_BwE
https://www.ebay.com/sch/i.html?noro...e%3ABY_VEHICLE
