Need help!
Need help!
I have an 05 mustang v6 automatic trans. About once a month I will go to start it and it is completely dead. So husband told me to take the ground wire off battery and wait 5 mins and put it back on and see what it does . I done what he said and it fired right up. Can anyone explain what might be going on . And the last time it done it my window would not go all the way up and the car lock light was flashing . I have took it to advance and they checked the battery and the alternator and there were no problems.
[QUOTE=Ryan Stocker Jackson;7011106]I was going to try to put new ones on it . But they aren't that bad tho.[/QUOTE ] I'm not sure about the stereo. It's a touch screen the owner before me put in . It's a pioneer bt2400 I think
Like Jazzman says, even though the battery terminals don't look to bad you may need to get a terminal brush, and clean them good. It doesn't take much corrosion to cause problems. Good luck.
If you don't have a brush you can pick one up at your local Wally World, or Auto store. And clean both neg., and positive to make sure.
