Keeping the Engine Clean...Safe to Hose?
Old Nov 10, 2014 | 10:16 PM
oceantracks's Avatar
OK newbie question here as I'm not a car tech type....have a 2014 GT and wondered about what you guys do (if anything) to keep the engine looking nice. Is it safe to hose the whole engine once in awhile?
Tips appreciated!
Tom
Old Nov 11, 2014 | 06:58 AM
TripleBlack14's Avatar
Tips appreciated!
Tom
Is it a DD? Garage kept? If so, you really shouldn't have to clean it much. Mine is a nice weather car and garaged when not in use. I wipe down the engine bay completely after each wash and detailing session to remove dust and water spots that accumulate on the shock towers, fender lips, and hood underside....everything I can reach.
But if you drive yours a lot and in all types of weather, I think steam cleaning would serve you better.
Old Nov 11, 2014 | 08:26 AM
Critical Mass's Avatar
I just wipe it down once a week. I'll only hose it if it's been a year or more. On other cars I didn't really care. On this one, it's worth the extra five minutes to give it a good wipe down, especially with all the chrome/aluminum underneath the hood that I've added.
Old Nov 11, 2014 | 08:35 AM
Joeywhat's Avatar
I spray with 303 aerospace, use a brush to clean everything off then spray it down with distilled water. I'll then wipe more 303 on the exposed bits to make everything look nice.
Old Nov 11, 2014 | 09:47 AM
gjcavana's Avatar
I'm kind of wondering also, is it ok to spray off the engine with a hose?
Old Nov 11, 2014 | 10:57 AM
CiniZter's Avatar
not sure why every one is asking for hosing down the engine. all you have to do is spray some engine degresser and wip it up.
Old Nov 17, 2014 | 01:20 PM
Jek57's Avatar
Yes you can do it i did mine when i first bought it used the engine was filthy from a ford dealer no less. Just go to the dollar store get some cleaner cover the alternator fuse box battery i used foil spray it down with the cleaner make sure the engine is cold let it soak hose it down i didn't use a lot of pressure on it wiped it down . good to go
Old Nov 18, 2014 | 11:37 PM
kcoTiger's Avatar
Spraying your engine down with a hose is a good way to corrode your plugs. Do it to a hot manifold often enough and you can crack it. The dirtiest engine will come clean with degreaser and towels.
Old Nov 22, 2014 | 06:27 PM
poldrv's Avatar
Autoglym is the product to use. See video.
Followed by;
FromZto5
Sep 30, 2015 05:28 AM
mustangsally_
Sep 18, 2015 05:35 AM
samjluck
Sep 17, 2015 10:24 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 08:31 AM
