IAC VALVE
Old Sep 3, 2012 | 10:21 AM
jreal6192011's Avatar
IAC VALVE
I have a 03 mustang gt and just wanted to know if the car is suppost to shut off when u unplug the idle air control valve???? IAC??? PLEASE LET ME KNOW ASAP THANKS GUYS
Old Sep 3, 2012 | 06:01 PM
houtex's Avatar
Well... yeah. It's the idle air control. If it can't fix the air going in at idle, then the car might stall out due to being starved of air.
That's not to say a pristine throttle body might not let air in enough for it to stumble about trying to stay running, but a dirty throttle body might spell curtains.
So... I'mma go with maybe... and also ask, what's the need to know? Why are you disconnecting it?
Old Sep 5, 2012 | 10:25 AM
Im trying to see if the sensor was good ive been having a problem with my stang when it hit normal opperating tempature it wont go pass 3500-4k rpm and it feels like a rev limiter!!! It does it every gear u put it in 2nd and its hella strong till it hits the rpm i mentioned im stuck i need help
Old Sep 5, 2012 | 10:34 AM
AlsCobra's Avatar
A Man Just Needs Some....
Try a fuel filter first.
Old Sep 6, 2012 | 02:28 PM
I WAS THINKING OF DOING THAT AFTER WORK ILL KEEP U POSTED IF IT WORKED OR NOT THANKS!
Jtm90fox
May 22, 2016 01:55 PM
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
Airborne42
Sep 24, 2015 10:27 AM
bconboy
Sep 10, 2015 02:31 PM
BavarianStang
Sep 5, 2015 05:55 AM
